What am I doing wrong?!?!?!!?
Old Sep 13, 2011 | 07:05 PM
4g63evoeight's Avatar
Yea the car defiantly is not making the power, something is up.
In my 100% stock Evo best trap was 104.6 and it went 12.98@103
Old Sep 14, 2011 | 09:13 AM
Nofear23's Avatar
Originally Posted by RoninVIIIRS
Don't forget you said it was awful hot. There will be a difference in the real world condition vs. the dyno conditions at English. It could very well be that your car just doesn't do that well when it gets that hot. Check your boost leaks and make sure everything is in order. Go make some passes on another day where the weather won't play as much of a factor so you will get a better idea.
The day I ran the 105 trap speed it was only about 70 degrees out..
Thanks everyone for all the replies. I will be checking for a boost leak this weekend and will let everyone know.
Old Sep 15, 2011 | 06:07 AM
1NastyMR's Avatar
Originally Posted by Turbojunkie
Definalty look things over. I trapped 116-120 with 377whp hp on the dyno at drift office ( set up the same as er's). A stock evo traps 103. https://www.evolutionm.net/forums/dr...h-stocker.html This was done with 377whp. Mods were, E-85 tune, cams 272/272, full exhasut, and a boost coller, Exexy twin for a clutch. Stock fmic, stock 02, stock turbo and manifold.
Your signature says you ran Hoosier Slicks? Thats why your trap speed is high like that. 377 hp doesnt trap 116-20 on street tires, not that ive seen unless car is light atleast unless thats Mustang #'s and your making 400+
Old Sep 15, 2011 | 07:47 AM
Turbojunkie's Avatar
LOL.Look at the date of the thread i posted bro! Not slicks. Drag radilas. I got the hoosiers ( DR's) long after i had done these times. And, yes 377 does trap those times cause i do it all the time. search my screen name, you will find everything i have ever done to my car.
Old Sep 15, 2011 | 08:58 AM
partyboy1122's Avatar
I would double check the tune. Sounds like a knock storm is happening here.
I was trapping 108mph with 12.7s-12.9s with a turbo back/tune.
Old Sep 15, 2011 | 09:05 AM
Nofear23's Avatar
Would there be any indication of knock (such as when the check engline light would flash on my DSM when I was using DSMLink)? I don't have a tactrix cable to do any logs.
Old Sep 15, 2011 | 10:48 AM
Yes. ask your tuner if he has the knock light set up. I had my SES or CEL set up to flash once you hit a pre-set amount of knock. Very usefull.
