Weight loss plan...
Old Dec 18, 2011 | 06:28 PM
TurboTravis's Avatar
Weight loss plan...
Not me, I'm getting more out of shape day by day, lol...
The car scaled@3200 on the dot without me in it and a near full tank. Since then, I've removed-
-Backseat/belts
-Rear speakers
-Rear wiper
-Everything from trunk
-Floormats
And installed-
-STM small brake kit.
With that said, the car is sitting at about 3110 right now with the same fuel load. Next seasons plans are-
-ABS removal (10lb)
-AC removal (30lb)
-RPF1 wheels (20lbs less)
-Cabin floor sound deadening material (10lb)
So, with all of that, it'll be sitting at about 3040.
Obvious options are Mustache bar (13lb loss), front engine/tranny brace (6lb loss), coilovers (20lb loss)...and a few other lightweight aftermarket parts.
Things that I WILL NOT do/remove are
-Rear bumper bar removal
-AWD driveshaft (too many recent horror stories with them and the product itself)
-Firewall sound deadening (simply do not feel like removing dash)
Ok, enough rambling. Anything cheap/easy that I'm missing?
Thanks guys!
Travis
Old Dec 18, 2011 | 06:31 PM
Chaz17's Avatar
all the in-dash components? heat/ac unit and radio? carbon fiber hood/trunk. different side mirrors, steering wheel, race seats. and a tbe
then go on a diet yourself and shave a couple more pounds for the car
Old Dec 18, 2011 | 06:34 PM
detroit pistins's Avatar
looks like u got a nice plan together. not sure if ur aware of this thread, but u should give it a read.
https://www.evolutionm.net/forums/in...have-done.html
gl!
Old Dec 18, 2011 | 06:49 PM
Thanks for the suggestions. The heat/ac unit is staying along with the stock steering wheel. Seats are def a possibility though, along with CF trunk.
Old Dec 18, 2011 | 06:56 PM
EvoDan2004's Avatar
-Backseat/belts
-Rear speakers
-Rear wiper
-Floormats
And installed-
-ABS removal (10lb)
-AC removal (30lb)
Thanks guys!
Travis
the ABS delete is not 10lbs. i just did it. its 6.5 at the most there is a lot of other parts you can buy that are not listed on your list. give us a mods list and we can see what you have or can replace with a part that is lighter.
it all depends on how extreme you want to go.
Old Dec 18, 2011 | 06:59 PM
Chaz17's Avatar
also, small battery kit & as many carbon fiber parts you can think of lol (wing). even lighter rims, (volks). you can talk to the guys over at ssp hes got a bunch of weight reduction going on, probably has some good ideas he could share.
Old Dec 18, 2011 | 07:36 PM
Mod list is..
Full Race header/HTA 86
Buschur mini battery
DI Intake
Buschur FMIC
Buschur DP
Buschur Fuel Rail
Buschur Cams
GRP aluminum rods (light, lol)
FJO Wideband
Carbonetic clutch
TRE rear end
Stock ECU speed density
ID 2000's
Old Dec 18, 2011 | 07:40 PM
R/TErnie's Avatar
what the story with teh AWD driveshaft?
Old Dec 18, 2011 | 07:49 PM
Their customer service has had a lot of bad reviews as of late, and I know of at least one person that received one that was completely out of balance.
Old Dec 19, 2011 | 09:23 AM
rodent's Avatar
I had my local driveshaft shop make a 2 piece and it worked perfect. Basically a 2 piece alum and he offers a chromoly option for the smaller steel shaft and a stronger ujoint in the far rear. I'll post up some pics later.
Old Dec 19, 2011 | 05:26 PM
I'm very interested!
Old Dec 19, 2011 | 10:30 PM
kanyonkid's Avatar
i'd work on rotational weight before dead weight, a nice flywheel/clutch, wheels/tires, coilovers, small brake kit goes a long way specially with ur 3586. should easily get high 9's@150 with a full weight evo.
Old Dec 20, 2011 | 03:27 PM
As my OP states, the car already has the small brakes. Thanks!
Old Jan 5, 2012 | 08:20 PM
lillev23's Avatar
Wow. I have one of the original driveshafts when they first came out (early 2009 I think) and it has been absolutely perfect. I've daily driven for about two years with it and raced it pretty hard.
Old Jan 8, 2012 | 02:12 PM
HyboostN's Avatar
Wink
Same here. no issues at all. Been dealing with Mike and Shaun for a few years and have always given me good advice and parts have been received on time with zero issues. Sorry for your bad luck, it happens and Im dealing with something similar somewhere else also.
