16" rim advice
16" rim advice
need help picking out an affordable set of light weight 16" rims that i will be using with QTP's, i dont mind using a 20mm spacer up front..
i was looking at the rota slipstreams 16" x 8" anybody using these with slicks
John
John
16 x 7 Motegi Traklites +35 fit w/o spacers and weigh 12.5 lbs each. You can get them on ebay for $800-$900 shipped for all 4. They require small brakes. I used them with my QTP's and loved em.
Or buy FD RX7 rims (13.8 - 15 lbs each depending on what ones you get) and are 16 x 8 and require a 20mm spacer up front. They will clear the OEM brembos. You can get these for $300.
Hope that helps.
Hope that helps.
You can get rota slipstreams 16x7 40+ offset with spacers up front. They go for about 550 for all 4. Seen a few people use them on here with QTP's. Do a search and should see.
https://www.evolutionm.net/forums/dr...ck-brakes.html
https://www.evolutionm.net/forums/dr...fit-evo-2.html
16" RX-7 or slipstreams -----300 - 550
16" QTP's---------------------820 ish
Spacers-----------------------130
The other way would be everything above but the spacers. Then add the small breaks.
Small break set up------1000ish.
My set up I spent a little over 1100 dollars. If I had got the small breaks it would of been over 2000 something.
Sorry dig up a month old thread but where did you find 16x7 +35 wheels???? All I see is +40 and +42.
