Certified to 10.0/135MPH
Old Feb 10, 2012 | 09:56 AM
ilikeppie's Avatar
Okay so I have been searching and reading and I think I know what all I need but wanted to hear from people with experience here. I know I will need the 6pt roll bar the 5pt harnesses, the sfi approved clutch and flywheel, sfi harmonic balancer, scatter shield. Do i need a drive shaft loop? what about steel valve stems or wheel studs? anything i am missing? Thanks for the advice in advance!
Old Feb 10, 2012 | 11:30 AM
R/TErnie's Avatar
I know you'll need a driveshaft loop
Old Feb 10, 2012 | 11:46 AM
ilikeppie's Avatar
even with street tires?
Old Feb 10, 2012 | 11:58 AM
Wheatley's Avatar
they are fairly cheap and easy to install. Buschur sells one if you don't want to make one yourself. Direct bolt in and black powder coated.
Old Feb 10, 2012 | 12:38 PM
boosted91t's Avatar
From my experience, every track is going to vary. The cage is obvious, clutch, fly and scatter shield not soo much. Of the tracks I have been to the cage, harness manufactore date, and helmet were the biggies. If you are only going to a certain track it might be best to ask. I actually have a threespeed scatter shield, and a loop that never made it on the car and rides along in the trailer
Old Feb 10, 2012 | 01:08 PM
ilikeppie's Avatar
right on, yeah that is kinda what i figured that the cage and the harness would be the big ones. the cage is a lot more expensive than i originally planned though :/
Old Feb 10, 2012 | 06:50 PM
Sean@Iveytune's Avatar
6 pt, harnesses, and a scattersheild you should be good to go down to 10.0 at most NHRA tracks.
IHRA tracks are alot more lenient as the safety standards per ET are more relaxed.
Sean
Old Feb 10, 2012 | 09:46 PM
Pirana's Avatar
Good to know.
Old Feb 10, 2012 | 10:00 PM
Gordian79's Avatar
Not sure if they even check for loops on axles anymore but back in the days some tracks checked for them on z,corvettes etc anything with irs
Old Feb 17, 2012 | 07:27 AM
Donkeypuncher's Avatar
I just installed a loop and scatter. For most tracks around here (they just closed the only one that didnt care) they require that stuff. The think the difference is usually NHRA versus IHRA rules.
Old Feb 25, 2012 | 06:26 AM
johntsi's Avatar
This year a lot of tracks are requiring a catch pan for any turbo car as well.
Robevo RS
Jan 14, 2012 06:18 PM
ralliartsmart
Apr 2, 2011 08:34 PM
AWD Motorsports
Mar 28, 2010 10:37 AM
TrinaBabe
Nov 30, 2005 09:39 AM
en1gma19
Nov 18, 2005 11:27 AM
