Drag Racing - gear ratios??
Old Aug 20, 2012 | 09:19 AM
Conrad's Avatar
Question Drag Racing - gear ratios??
For all you guys that are running 160+ terminals in 4th gear what setups are you using?
Do you use RS or GSR or custom ratios?
4.11 drive?
What tire sizes do you run on DOT tyres? MH 26.5, 15 inch wheels?
What RPM do you need to run in 4th on the above setups snd what potential terminals would it give you?
Thanks for the help
Old Nov 24, 2012 | 06:17 AM
doghouse's Avatar
I also would like to know this
Old Nov 24, 2012 | 08:10 AM
Boostin Perform's Avatar
Evo 8 4th gear + 4.53 (stock) + 26" M/T = 9250-9350 rpm and low 160 mph traps
Evo 8 4th gear + 4.11 + 24.5 M&H = 8900-9000 rpm and 165+mph traps
Devin
Old Nov 24, 2012 | 08:49 AM
JohnBradley's Avatar
26" tires grow somewhat the faster they spin, so there is some variable gearing gained there. Normally its 26s, stock gearing with VIII 4th, 9600+ rpm.
The new drag car that we (ETS/ER) are campaigning uses a PPG dogbox which is 1:1 4th gear, 4.30 FD, and 26" tires.
Old Nov 25, 2012 | 05:33 AM
doghouse's Avatar
My car is an evo 7 with jdm evo 6 rs gearbox and rear diff. I was told that I may finish the 1\4 mile in 5th is that the case?
235/40/17 tyres
Old Dec 31, 2012 | 09:21 AM
NODAKevo's Avatar
I believe you should be finishing at the very end of 4th if your rev limit is unchanged.
Old Jan 19, 2013 | 01:35 PM
irace2much's Avatar
Hmm... so with my stock evo 9 trans and 26" Hoosiers
I won't finish in 4th gear about 155mph?
Old Jan 20, 2013 | 05:56 AM
doghouse's Avatar
thanks
Old Jan 20, 2013 | 06:04 AM
16vTAWD's Avatar
http://www.jackstransmissions.com/pa...on-gear-ratios
Old Jan 21, 2013 | 12:10 PM
badev0's Avatar
http://www.f-body.org/gears/
You're welcome.
Llew
21
Nov 19, 2025 06:38 PM
kartectuning
12
Nov 17, 2022 07:44 AM
jameswwt
16
Mar 19, 2013 09:09 PM
foxbat
Mar 6, 2013 07:59 AM
adammartini
Dec 21, 2009 07:07 PM
