launching help
Old Sep 21, 2012 | 09:02 PM
slowonder's Avatar
launching help
bout a month and a half ago i went to the track. its never really bugged me until now reading though these threads bout 60's and stuff. my best 60' was a low 1.9 slipping the clutch hard. now im still on stock t-case trans clutch and rear end with 105k on the car. mods are buschur turbo back buschur intake grimmspeed boost controller at 20psi (stock tune still) and torque solutions rear diff mount bushings. am i being to gentile on the launch? car went 13.4 at 105. im launching at about 5-5500 with no 2 step. im just really afraid of breaking the t-case right now
Old Sep 22, 2012 | 04:27 AM
vaflyboi757's Avatar
Try launching at 6k. Gas pedal all the way to the floor and a quick slip of the clutch. Remember, the key to not breaking drivetrain parts its avoiding drivetrain shock. So easy off the clutch slowly till you feel the car start to wanna move forward and then slip. You can also use the handbrake.
Old Sep 22, 2012 | 04:41 AM
GSR ONE's Avatar
Preloading is a very good way to avoid shocking the drive train to much.
Old Sep 22, 2012 | 06:46 AM
FL_SilverEvo8's Avatar
also stay away from wheel hop. That is what messed up my t-case.
Old Sep 22, 2012 | 03:15 PM
slowonder's Avatar
yeah i know all bout the shocking part i do preload it a little just not enough to start rolling. i wanna try to go again before the year is up so ill post results again. thxs guys.
Old Sep 24, 2012 | 08:35 PM
droppinbottom's Avatar
I handbrake mine on the launch. Everything is stock on my driveline except the clutch.
Old Sep 24, 2012 | 09:52 PM
itsmrrizz2you's Avatar
Once you light up the first staging light start lifting up the clutch slowly till it rolls forward and light up the next light then hold the hand brake up with the clutch in the same position as it is pre loaded. Then rip the hand brake down and the clutch at the same time. It's okay you don't have to slip the clutch as your already pre loaded. This has got me 1.6 60fts almost every time. I know it sounds like a lot but it's not. I do it in my videos if u wanna check it out you can see exactly what I'm doing
Old Sep 24, 2012 | 09:56 PM
https://www.evolutionm.net/forums/dr...pro-video.html. Check out the thread of u like I'm on 100% stock drive train with a act street disk clutch. Your rear diff bushings also help launch which is good for u
Old Sep 25, 2012 | 06:40 PM
slowonder's Avatar
yeah i was thinking that it was alot of work but i see now that it is very easy. definitly going back in a couple weeks so we shall see. ima have to practice this one
Old Sep 27, 2012 | 09:42 AM
420a-t's Avatar
When you say "with the clutch in the same position as it is preloaded" do you ,ean that whole time while waiting to go you have your clutch slipping a little bit, or is the pedal all the way to the floor? I would think riding the clutch for that long can't be as good as the "slowly let the clutch out until it grabs a little then let it rip" method.
Old Sep 27, 2012 | 09:53 AM
Yea I wouldn't stay on it that long because you will be eating the disks away. Just once that second staging light comes on I start bringing the clutch up till I feel it grab and by the time you do that the lights are coming down already. That's another reason y I always let the other person I'm racing stage first so once I light up that second staging light I just pre loaded and then the lights come rite down in 2-3 seconds. I wouldn't stay pre loaded any longer than that and u do it as lightly as possible the clutch should barely be ing aged it's just that point where your rite there. I'm not the greatest at explaining these things lol
Old Sep 27, 2012 | 09:56 AM
It's like I'm feathering the clutch while that second light comes on. Also I know exactly where my clutch catches
MisUnderStood
22
May 28, 2015 08:17 AM
Deannn
Driving Techniques
17
May 12, 2009 10:38 AM
Hiboost
Apr 21, 2005 07:25 PM
plokivos
Aug 8, 2004 05:50 PM
d16civicturbo
20
Jun 17, 2003 10:07 PM
