Evo X Drag Times list
The video of our journey into the 10's on pump gas,
Shout out to E-spec industries for making it possible!
https://m.youtube.com/watch?feature=share&v=cHXDRRsQB9c
Great Job, I wish we could have nicely prep track like that.
Which turbo you rocking you never mentioned in any of your posts it just said stock frame. Sorry I'm being so cautious but I've had guys try to tell me GTX35r bolt ons are stock frame and fp greens are stock turbos lol. Let me know and I'll change it for you.
Well, I am rocking a ATP GTX35r, a similar set up to (BLUEX), who is listed as the fastest stock appearing turbo GSR on the list.
If I have misinterpreted the definition of a stock appearing turbo, this is due to what is posted on the list.
I would agree that a stock turbo is a (unmodified stock turbo) and a stock appearing turbo is as its says (Appearing).
I try to go with Buschurs rules on these things for his event but even his explanation is kind of vague
STOCK APPEARING
"-Any FWD/AWD-Eclipse, Laser, Galant VR4, Evolution 7's, 8's, 9's, X,Genesis Coupe, 420A, 1.8 liter Mitsu, 4B11T, Stealth-3000GT
-Car must retain stock appearing intake manifold. Turbo must use the stock bolt pattern from the exhaust manifold/header to the turbine housing and be located in the stock location. Forced Performance Greens, Reds, Blacks and HTA DSM86's are considered legal for the class. Sheet metal 02 housings with recirculating or open dumps OK, must dump under the car. The new FP turbine housings for the turbos listed above using the Tial external waste gate is allowed. External dumps must exit below the vehicle. Full exhaust exiting the rear of the vehicle is required. FMIC, intercooler plumbing, turbo inlet with air filter, small battery kits are all OK for this class. Both headlights must be installed and working. Beyond those mods the car will not pass for stock appearing. DOT RADIAL TIRE ONLY. NO tread wear rating limits. No half radiators. Full interior to include all seats, door panels, rear hatch cover on DSM's, carpet, head liner, dash etc. Wiper, mirrors and factory glass are required.
-On your windshield you will put in large print, SA followed by the number from your tech card. This is your class/car number for the day.
-Pro Tree"
I'll reach out to Buschur and see what he thinks about the atp stock flange 35rs if they are stock appearing or aftermarket.
Stock housing just modified to fit a bigger wheel like the FP and Map turbos. The Garrett Bolton are a totally different unit. So it's been argued to me they are not stock appearing they are just stock location and bolt on to stock flange.
STOCK APPEARING
-Pro Tree"
STOCK APPEARING
-Pro Tree"
It's unfortunate that my posting would result in his accomplishment being taken away. This wasn't the result that I was hoping to see.
You Posted that a ATP GTX35r is a stock location turbo and this is true. But I would also like to add that is can be used with a stock down pipe, stock manifold and stock air box and pretty much appears stock. Hence the term stock appearing.
I appreciate your effort and think that your listing is a great thing. I view it as a way for a group of international guys to compete with out being on the same track.
And it must be said that it promotes the use/sale of these performance parts world wide.
What I find that is not right, is when the bar is being moved for seemingly no reason. BLUEX, myself and others would have put in great effort to be on your list and others are still working to be on your list, the bar should be stationary.
If your seek advise from Buschur,(great guy) this should of been done before removing anyone from the list.
Please view a link below of a chat, on Evoutionm with EVO 8 and 9 guys interpolation of a stock appearing turbo.
Note that number #2 on the list is a ATP GTX35r turbo
https://www.evolutionm.net/forums/dr...os-2012-a.html
Thanks for your time and keep the list going strong.
A year ago BLUEX was listed as the Fastest stock appearing turbo GSR EVO X and at that time this wasn't questioned and he clearly listed the turbo that was used.
After speaking with DB The Garett turbo is going to be considered a stock appearing turbo. This will make it allowed for the stock appearing class at the Shoot out events and I'll also change back the 1/4 times list of course.
So
1. moved BlueX and Talanted back to the stock appearing list
2. Added Mitsuwut to the stock appearing list since I didn't even have him on it a few days ago lol
Look over things and let me know
Edit
blue x gets fastest 1/4 trap speed with a 138.35 trap speed and 1/8 trap of 107.35
https://www.evolutionm.net/forums/dr...l#post10837766
again guys any questions or concerns please just ask and if you don't agree just plead your case and we'll work on it. When aiming for accuracy some things fall into a gray area. Hell I found 3 other little mistakes in the list just reviewing this stock frame thing so its good to keep going over it to make it as accurate as possible.
Thanks for the update. I appreciate you taking the time to look into the matter for my.
sorry for giving you extra work today!!
