People's 60-130 mph times?
not that I can find at the moment but we checked it through a V-Box. Was done at the shift sector event. I thought we had one showing the speedometer. I'm still looking for it.
We have plenty of videos of it doing 8.2 in the 1/4mile and 213 in the half mile though.
Car makes right around 1600WHP Dynojet.
Here is the data and youtube video.
https://www.evolutionm.net/forums/ot...ish-tuned.html
Thanks!
Michael
Runs from Saturday 8.23 @ 177mph
Tuned and Driven By English Racing.
Fastest / Quickest run of the day
60-130 - 2.78 Sec.
1572whp / 1179trq
Mod List
ETS 4.1L Motor
ETS 5 Axis CNC Heads
ETS PT6466 Turbo Kit (Available By Phone)
ETS Race Intercooler Kit
ETS 4.0" Titanium Exhaust System
ETS 4.0" Intakes
English Racing Pro Tuned
Cobb Accessport
Syvecs 4WD Box
BL Intake Manifold
Greddy Throttle Bodies
Got Boost Speed Density Kit
Got Boost Catch Can
Injector Dynamics ID2000cc Injectors
AAM Triple Pump Fuel System
ETS/Shep Built Transmission w/ Shep/Dodson Custom Promax
T1R Transmission Brace
60-130 - 2.78 Sec.
1572whp / 1179trq
Mod List
ETS 4.1L Motor
ETS 4.0" Intakes
Cobb Accessport
Syvecs 4WD Box
BL Intake Manifold
Got Boost Catch Can
Thanks!
Michael
Correct me if I'm wrong but 60-130 times are based on a rolling 60 mph start, not a drag strip already going flat out starting with the 60 mph mark? There would be a difference between the two I'm fairly sure of it.
I believe that most 60-130 times recorded are started before 60 so you can have momentum already, if you were to start at 60 your time would suffer a little though. So your theory is correct to the rolling part , but weather you start at say 50 mph to have momentum by 60 it shouldn't be any different then flat out at the strip. As far as I know the data at the strip is totally different as you get 60', 330, 1/8, 1000' and 1/4 and there getting that 60-130 off either a v-box or some other sort of acceleration test equipment.
From what we know all data is based off of hitting 60 mph at full power. The V-Box data is the only true data you can trust. Just like a Dynojet Dyno.
My EVO at 700hp running 10.6@139 was around 6.1 60-130 if I remember right but I had the 2-3 shift just after 60mph which I think killed my # some but even with a hard boost break in 3rd and only doing a 3-4 shift high 5s I would have been my best. The GTR's are a whole other level. The ETS GTR never drops under 1550hp during a pull ware a 700hp evo might only avg 650hp under the curve and the more hp they make avg hp under the curve vs Peak # grows.
That is all true, I was rolling into 60mph. I believe I started at 40mph ish. The V-Box is really only data I trust also.
How many shifts occur between the timed window can have a big impact. Doing a 100-200KPH run from a dig would add an extra shift on this car but starting from about 50MPH took away one shift and the time improved. This is the only data I have to contribute at the moment. Sorry it's not evo related.
Audi TT-RS APR stage 3 kit on pump gas, manual transmission 6-speed.
You can't beat the P-box / V-box data. Nothing is better to compare usable performance results across all platforms.
My best 60-130 times came with a single gear. 100 shot nitrous to spool and one gear only.
Its not an EVO, its a BMW M3 twin turbo.
In Rear Wheel Drive mode 4,2 s has been my best so far. RWD & Manual transmission.
Suffered due to loss of traction and limited to 4,2 seconds.
Boost pressure was 35 psi / 3500 cc stroked M3 engine / 9000 rpm / methanol fuel / Twin GTX3076 turbos
Been working on an all wheel drive M3 twin turbo lately, it will have better traction and has an automatic transmission. Hope to see low 3 seconds 60-130 times.
At the same time preparing another RWD M3, auto transmission twin GTX30, this RWD M3 should see 3,4 s 60-130. Initial road tests gave hope, been able to cut 1,88 s 60-100 mph.
I like Evos and been following this forum with pleasure.
Do you have any video's of your 60-130 runs in your m3? I have always liked m3's and would like to get a e46 one in the near future. I have owned 2 e30 m3's and a 4dr e36 m3. It was a big mi$take selling my e30 m3 as their worth big $$$$ now.
Videos had to be removed from youtbe as they were on a highway....
Two of my M3s are listed under my username Twinturbom3 at :
http://www.6speedonline.com/forums/9...le-thread.html
Both my E36 / E46 M3s are listed here.
I would not recomment to get an M3 to work on as its RWD nature makes it difficult to stick to road. I have been working very hard to get these times.
It also costs a lot as there is no bolt on, off the shelf turbo system, engine management etc. Every part is custom made, custom manufactured.
The good side, S54 is a very good engine, stroked to 3,5Liters it makes good power/torque.
Andrew@AMS
Automotosports - Illinois
10
Aug 4, 2013 08:30 PM
Andrew@AMS
Jun 10, 2013 07:19 AM
