Traps vs rpm, 4.11 needed?
Old May 25, 2014 | 08:19 AM
420a-t's Avatar
I'm looking to see what others are crossing the 1320 at with either a stock FD or a 4.11, and if you use a 4.11, what are your 60'? I read that you can get better than a 1.6 60' if you have a 26" tire.
I'm looking for high nines, staying under 9000rpm, and using my qtp 26"/ fd combo full weight. If I can get away with stock gearing, I'd like that as it's just one more part I'd have to buy. If I stay stock gearing, would I benefit from an evo 9 1st gear?
Thanks for any info
Old May 25, 2014 | 09:27 PM
AreSTG's Avatar
don't know if stock gearing will be enough, but I can say for damn sure that on a 26" tire you'll be way below your RPM limit on 4.11
Old May 25, 2014 | 11:17 PM
420a-t's Avatar
Ya I heard 60' would suffer on a 26" tire and a 4.11. I guess I'm looking to see what mph equals what rpm in the 1/4 with a stock FD. Like 140=8xxx rpms, 150=8xxx rpms, etc.
I'm looking for high 9s full weight on a 2.2l 6466
Old May 25, 2014 | 11:30 PM
AreSTG's Avatar
I'd love to help more, but I only ran a 26" tire once. It was a 9 sec run, lol, but I wasn't paying attention to rpm or anything on that run.
on a 2.2L i bet you're good with stock FD with 26" tire up to 155mph, you can rev. I played it safe for the 2.4L.
But, I'm sure guys with more experience on 26" tires will get in here and help you when normal people are awake.
Old May 25, 2014 | 11:33 PM
AreSTG's Avatar
I did a 1.59 60ft on 4.11+26" tire.
Variables: 2.4L, I had no 2-step, first time on QTPs
I'm no expert but I think 1.4 is doable on 4.11/26" tire, vehicle weight might hurt it some
Old May 27, 2014 | 09:27 AM
420a-t's Avatar
Thanks for the info, I appreciate it. I am full weight pretty much (3200lbs).
So, stock FD I'm guessing on a 26" tire I would be crossing around 8700 with a 140mph speed?
Old May 27, 2014 | 09:51 AM
AWD_Launch's Avatar
Stock Final Drive Ratio: 4.529
Gearing VIII/5 - IX GSR- IX MR
1st Gear 2.928 - 2.785 - 2.909
2nd Gear 1.950 - 1.950 - 1.944
3rd Gear 1.407 - 1.444 - 1.434
4th Gear 1.031 - 1.096 - 1.100
5th Gear 0.720 - 0.761 - 0.868
6th Gear -.--- - -.--- - 0.693
Speed with stock final drive, 7500 RPM:
------------ 4th --- 5th --- 6th gear
VIII 5speed: 121.7 - 174.3 - n/a
IX GSR 5spd: 114.5 - 164.9 - n/a
IX MR 6spd.: 114.1 - 144.6 - 181.1
Speed with stock final drive, 8000 RPM:
VIII 5speed: 129.8 - 185.9 - n/a
IX GSR 5spd: 122.1 - 175.9 - n/a
IX MR 6spd.: 121.7 - 154.2 - 193.2
Speed with HKS 4.11 final drive, 8000 RPM:
VIII 5speed: 143.1 - 204.9 - n/a
IX GSR 5spd: 134.6 - 193.8 - n/a
IX MR 6spd.: 134.1 - 169.9 - 212.8
Speed with TRE 3.84 final drive, 8000 RPM:
VIII 5speed: 153.1 - 219.3 - n/a
IX GSR 5spd: 144.0 - 207.5 - n/a
IX MR 6spd.: 143.5 - 181.9 - 227.8
Old May 27, 2014 | 10:01 AM
AWD_Launch's Avatar
About 8500 with the 4.11 final drive should give you enough MPH for high 9's assuming a good 60 and driver.
Old Jun 7, 2014 | 01:10 AM
Teal2nnr's Avatar
Good thread on it https://www.evolutionm.net/forums/dr...shift-5th.html
Old Jun 8, 2014 | 05:36 PM
420a-t's Avatar
Thanks guys I decided to stay stock fd and an evo 9 1st gear instead. High 9s here we come
Old Jun 8, 2014 | 06:15 PM
Macaroni's Avatar
I'm on QTP's with stock gearing but I'm not stock weight. 1.62 60ft with 149 being my highest trap around 8700 rpm. Sitting on the limiter a good second before going through the traps.
Old Jun 8, 2014 | 06:50 PM
420a-t's Avatar
Thanks for the real world info man. I figured I'd save some coin and go with the stock fd for this year. And I built my 2.2 to rev up to 9k-9500rpms so I figure it can handle it for now.
Thanks
Old Jun 8, 2014 | 08:24 PM
Macaroni's Avatar
I think 9k would be right at the trap beams on stock FD with 26". I'll let you know in a couple months lol
Old Jun 8, 2014 | 08:39 PM
detroit pistins's Avatar
Thanks
What clutch will you be using at that rpm?
Old Jun 9, 2014 | 12:33 AM
420a-t's Avatar
QM 8 leg with a higher tq. capacity pressure plate.
