Evo keeps breaking shafts
Hey guys,
So about 2 months ago I got my car tuned. The following week I took it to the track for the first time on the new setup and on the third pass broke the rear driver axle shaft. Put a new one in and took the car to the Buschur shootout 2 weeks later. On my 5th pass I broke another axle shaft (Passenger rear this time) The Boostin performance guys just so happened to be watching that pass and in the pits told me my car needs solid diff bushings. I currently have energy suspension poly rear diff bushings. Could this be my issue or is it time for upgraded shafts? The car makes about 740hp/530Tq
I am using M/H drag radials at around 15psi. What's interesting is how the shafts are breaking. Both shafts broke at the splines in the diff. What's also interesting is that the first time I broke a shaft the CV boot on the other side had popped off as well. It looks as though the diff is moving and the clamps on the boots are actually hitting the body. I'm thinking when the diff moves it puts the shafts at an awkward angle and therefore causing them to break where they do. I have a set of solid diff bushings on order but If anyone has any other ideas/suggestions that would be greatly appreciated!
Pic of the broken axle can be seen here on the first page:
https://www.evolutionm.net/forums/ev...-mani-e85.html
I'm surprised the rear diff would be moving enough with those poly bushings to break the axles like that, but it sounds possible if they're really hitting the body. I was thinking of downgrading to poly bushings due to the noise from the solid bushings, but I think I won't.
What are your 60's? Is the car dead hooking? I would imagine its not at 15psi.
Im going to try the torque solutions mustache bar eliminator with the solid bushings. I really want to avoid dropping the big bucks on shafts especially if I can get away with the stockers.
I've broken 2 rear driver side axles. I have all of the Buschur rear diff supports and it is still an issue for me. I doubt it is the rear end moving that is breaking them. It is obviously the weak point. Sounds like it is time for DSS axles.
How many passes did you get out of the stock shafts and where did they break? I'm pretty sure you are making significantly more power than I am.
I now bring a spare set with me every time I race lol. But to be honest I'll probably shell out the money and will buy the DSS axles next time it breaks.
They always break on the spline that goes into the rear diff where it connects to the cup.
I have had hundreds of launches and have only broke one rear axle. This was on a wheel hop on some terrible nitto drag radials. I tend to be easy on my launch with less then 10psi of boost on a launch, usually netted low 1.5 60 foots.
Also, if you bought a used axle it may have been abused before it broke.
I have not re-arranged the diff plates. I got a killer deal on some DSS level 5 axles. I will also be ordering the torque solutions mustache bar eliminator with solid mounts. Hoping this will solve all my problems!
chmodlf
60
Oct 23, 2018 08:59 PM
crcain
26
Aug 23, 2016 02:48 PM
Mauricio Evo IV
Oct 6, 2015 10:52 AM
memphis69
11
Jun 10, 2014 10:38 AM
