launch
Old Mar 23, 2004 | 07:51 AM
FilipinoEvo's Avatar
Exclamation launch
I need to know how i should launch my evo. I have been told to slip the clutch and to dump it. I launch around 5-6 rpms and all i do i bullk down. can someone tell me what im doin wrong. I have launched the car right a couple of times when i raced a srt-4 and a mustang cobra and i suck them both the hell up.
Old Mar 23, 2004 | 08:11 AM
raywong's Avatar
I had some sucess dumping at as low as 4.5k rpm a few months ago, but last week I tried to dump at 5.5k rpm and everytime the clutch slipped like hell. The clutch drives very well in normal condition so I don't think I should replace it just yet.
Old Mar 23, 2004 | 08:30 AM
mifesto's Avatar
if you "bulk down" or rather bog at start, its because you arent smooth with the clutch and gas pedal.... if you clutch out too quickly or not enough gas, your rpm is going to drop too low and your going to bog.... if you get the timing right, you can launch off fairly smoothly... i personally wont dump the clutch past 3k rpms, our clutch is so weak :P
Old Mar 23, 2004 | 08:36 AM
whitet777's Avatar
Well, what's worse, dumping the clutch at 5k or slipping at 3k??? I would say that slipping is worse for the clutch, but that's my opinion. I would rather dump the clutch.
Old Mar 23, 2004 | 08:39 AM
jerastan's Avatar
you dump your clutch. i'll keep my transmission. a clutch is a tad bit easier/cheaper to replace. just my opinion.
Old Mar 23, 2004 | 08:40 AM
whitet777's Avatar
That's the beauty of warranty
Old Mar 23, 2004 | 08:44 AM
Mister2zx3's Avatar
.. a warranty that's honored...
Old Mar 23, 2004 | 08:49 AM
en1gma19's Avatar
^^ exactly. don't be overconfident about warranty issues. especially when it's something as expensive as the tranny. mitsu isn't going to be eager to fix that. i say get a couple of mods, and then it'll be just as fast from a roll as it would be now with a launch. i've had my evo 8 months and i've only launched it maybe 5 times at most. But believe me, I still have fun with it
BTW......there are endless threads about this already. please try a search
Cannonballer's Avatar
So you are advocating slipping clutch right?
Old Mar 23, 2004 | 09:01 AM
whitet777's Avatar
Actually, the launch isn't as important to me anyways. I autocross and don't drag race. The launch in an autocross isn't nearly as important because the starting timer isn't until 20ft after the start. My car will be up to full power and boost within 20ft regardless of how hard I launch it.
Old Mar 23, 2004 | 09:56 AM
newevo8's Avatar
when the needle gets close to the number 8. Grab the wheel at 9 and 3 and let her rip.
Old Mar 23, 2004 | 10:16 AM
USP45's Avatar
I will slip my clutch any day rather then dump it. I have put another clutch in the car and if I have to do it again I will, I would rather have a good clutch that will slip at first and the hook up hard so that the drivetrain is loaded in a more gradual fasion. You are a lot less likely to break the really expensive parts this way. I have an ACT clutch in right now and it fits the bill perfectly. It slips a bit a first and then locks down and you are off.
Old Mar 23, 2004 | 12:57 PM
pwrd_by_diznutz's Avatar
press the clutch....de press i little bit until you start hitting the friction point.......pulse the gas 2 times at 5 grand........let go of the clutch fast but smoothly while you do that make sure you are letting go as much clutch as u are putting gas. If you do it too slow you will smell clutch big time, and if you do it too quick you will bog. It takes practice so good luck
dfarmer0033
May 18, 2017 08:43 AM
toyotabike
Feb 18, 2011 07:32 PM
bigguss69
Dec 13, 2009 03:37 PM
AirNKAir5
May 5, 2007 01:01 PM
k270kmh
14
Jun 25, 2004 01:17 PM
