How to have a good launch?
Old Jun 21, 2004 | 07:33 PM
k270kmh's Avatar
Hey guys, How to do a hard launch?
Some trick?
BTW, I would like to keep my stock clutch for a while.
Old Jun 21, 2004 | 07:35 PM
sleet's Avatar
Then don't launch.
Old Jun 21, 2004 | 07:42 PM
tweakdsm's Avatar
around 5,000 rpms and dump it......... dont slip the stock clutch
Old Jun 21, 2004 | 08:02 PM
1QWKEVO's Avatar
if u drop it... u iwll replace it
If you want to throw someone in their seat....
Rev the car around 2500 then nail the gas and keep it floored... as the RPM's climb to 5500 drop the clutch and DO NOT LET OF THE GAS! When you hit 6500 shift... good for sub 1.8/ high 1.7 60ft's
Old Jun 21, 2004 | 10:06 PM
Jonasan50's Avatar
No AWD car is meant to be launched...!! If you launch it, you'll break something and claim that Mits built a POS car... Same ole story over and over...
Old Jun 21, 2004 | 11:05 PM
SSKILLA's Avatar
who showed you to launch a awd thats all wrong.....plus anyways jons right ive been through 3 transfer cases launching the car .......havent had any problems since i stoppped launching
Just my .02 cents
Old Jun 22, 2004 | 10:55 AM
tweakdsm's Avatar
i got 17k on the car still stock clutch and its fine... oh well.
Old Jun 22, 2004 | 06:52 PM
Ev0 1's Avatar
Play around with the rpm alittle bit, going up to 5,500 rpm, hold it there and semi slip/dump it.
Old Jun 22, 2004 | 08:15 PM
BuLocal's Avatar
Some trick?
You just cant have it both ways!
Old Jun 22, 2004 | 08:29 PM
2GDSM's Avatar
buy a mustang or a corvette....or even an SRT-4....
Old Jun 25, 2004 | 01:33 AM
Inprogress's Avatar
so basically slipping like 1QWKEVO said is, keeping at 2500 while staging, then launching and leaving the clutch semi-engaged and once the car is moving and reaches 5500, then come off the clutch entirely and just go?...
sorry, but just trying learn the tricks
Old Jun 25, 2004 | 01:37 AM
Alias's Avatar
Originally Posted by sleet
Then don't launch.
Agreed!
Old Jun 25, 2004 | 02:16 AM
robvii's Avatar
mitsi put a weak clutch in the car for a purpose...this is the "weak link" and will slip before the gearbox goes or the transfer case explodes.
Old Jun 25, 2004 | 06:03 AM
NOVA EVO's Avatar
Rev to about 5K or so, then let up the clutch quickly, but don't sidestep it...slingshot time, baby!!!
Old Jun 25, 2004 | 01:17 PM
vicbdn's Avatar
rev to 3.5-4.5k, bounce it in between. When ready, rev to 6k+, sidestep.
the clutch should grip...and you want to try and induce a bit of tirespin. a 5k dump will most likely cause a bog + lots of tranny stress(i think). Slipping is hard to do, you might slip not enough which will result in a crappy launch, or too much and bog, or just end up with a glazed clutch.
Idealling(I think) you'll tirespin, accelerate very quickly and the tach should drop from 6k immediately to 3-4k~. That means it engaged and with the tires spinning hopefully there wanst much tranny stress. (tho any sort of non slipping launch I think will cause small to very large painful amounts of stress)
if you dump it at 6k and the rpms dont drop...then your clutch is slipping which is bad, so let off.
ant_turbo
Nov 19, 2010 05:55 AM
nestoledo
Driving Techniques
Sep 22, 2010 06:52 PM
robertrinaustin
10
May 27, 2006 11:55 PM
imsonastie
Nov 1, 2003 10:44 PM
FourG363
Jun 20, 2003 10:57 PM
