Visiting the 1/4 mile for the 1st time this weekend...
Old Mar 23, 2016 | 08:23 PM
Bmurray's Avatar
What kind of times can I expect with a ****ty 60'?
Evo IX ssl. 393whp / 411 ft lbs stock turbo e85..
100% stock drivetrain
any guesses? going saturday will post times when I get back
Old Mar 24, 2016 | 03:25 PM
tlcoll1's Avatar
Mid-12's at 117 and a very smelly clutch.
Old Mar 26, 2016 | 01:40 PM
Bmurray's Avatar
Ran today. Only ran 3 times. The one decent run I had, the car did something weird in 3rd gear which you can hear/see in the video. It bogged real bad then picked back up for a second. Idk what it is? Plugs maybe? Any input on that would be awesome.
Other than that, I had fun. The pass I mentioned above was a 12.74 @ 112.8mph. I really think if it wouldn't have bogged it could have been a 12.2-12.3 @ 117 or so maybe?
Old Mar 26, 2016 | 04:07 PM
tlcoll1's Avatar
12.1-12.2's definitely possible. Shift faster 1-2. Should be better MPH, even with the funny business in 3rd, though.
Old Mar 26, 2016 | 04:30 PM
Bmurray's Avatar
Gotcha. I'm gonna fix this little bug & at least get a better clutch in it and go back.
Old Mar 26, 2016 | 05:08 PM
High_PSI's Avatar
You need a clutch, but 112 MPH is your time. With a better clutch you may get better trap speeds but not 117MPH.
Old Mar 26, 2016 | 06:05 PM
roni4g63's Avatar
i think you hit boost cut
Old Mar 27, 2016 | 02:19 PM
tlcoll1's Avatar
High_PSI - I was expecting higher MPH as well. About 400 HP on E85 *should* be more like 117, right?
Old Mar 27, 2016 | 03:04 PM
Bmurray's Avatar
Can you elaborate? Excuse my noobness please
Old Mar 27, 2016 | 04:35 PM
ctfpevoVIII's Avatar
I just watched your video , what rpm did you leave at? It seems like you can leave the line a bit harder which will knock your times down as long as your clutch is up to it. I think your car which is about a 400 whp /400 wtrq should run quicker, with more practice you will hit 11's at your power level BTW nice wheels are those Work wheels?
Old Mar 27, 2016 | 05:12 PM
saxon's Avatar
no reason you shouldnt be able to get a 1.8 60ft which will lead to low 12's even with the weird 3rd gear issue. high 11's with a 117 trap
Old Mar 27, 2016 | 05:26 PM
Bmurray's Avatar
i think i left around 3500 or so. I am still on the stock clutch / drivetrain so didn't want to test the limits. Once i at least get a clutch in the car i will definitely go back and launch it a bit harder.
so without the 3rd gear issue, a 1.8 60', and good shifting... ~11.8-11.9 @ 117 or so? Is that decent for a stock turbo e85 272 cam full weight Evo?
Old Mar 28, 2016 | 04:49 AM
lostsoulsevo's Avatar
Yes upgrade your clutch, but don't worry about your stock drivetrain launching. It can take it at your power level. You need to be launching your car at 5k+. Don't worry about ET at the moment. Your trap speed is dependent on a lot of factors...weight being one of them. If you're full interior stock weight 117mph sounds about right for 400/400
Old Mar 28, 2016 | 05:08 AM
Bmurray's Avatar
Cool deal. I'm going to get back out there within the next couple months
and yeah, full ssl interior. only thing i've removed was the spare tire
Old Jun 14, 2016 | 08:04 PM
evoson23's Avatar
Here's my Evo 8 with 400hp 400tq with Hoosier dr tires
bnr34rb26dett
European Forum
27
Mar 30, 2012 11:13 PM
mydnyte93
Northwest Region
14
Aug 16, 2010 02:46 PM
Jake26
May 22, 2009 07:32 AM
superscout03
South Region
Apr 19, 2006 10:35 AM
vrrrm...psss
May 19, 2005 08:39 PM
