Quest for mid 10s did
Old Mar 29, 2018 | 11:54 PM
evo8vz's Avatar
Did 11.0 @ 123 with 1.63 60 ft on motorcycle slicks
Have an OG green on 2.3 stroker ran e30
Will going full e85 help me get down to the mid 10s? Have 14 degrees of timing up top but with full e85 i can get 18 degrees i think
also still running stock wga boost will only spike up to 28 psi
or dump this mess and just go for a red or black?
Old Mar 31, 2018 | 08:26 AM
Abacus's Avatar
You're close to the 10's. Even going to E85 with your current timing will help.
FWIW, a small turbo with a restrictive housing creates alot of backpressure . It gets worse as rpm increases. Adding a stroker compounds this. You don't want to keep adding timing to that situation. These engines don't require alot of timing and 13-14 @8000 is in the ballpark.
Old Apr 7, 2018 | 08:38 AM
asuarez's Avatar
Stay with the Green, go full e85 and swap your seat !
http://www.jegs.com/i/JEGS-Performan...02260/10002/-1
emotart
Jan 21, 2012 07:53 PM
evodave
48
Dec 23, 2004 06:29 PM
3000ways
14
Nov 6, 2004 12:43 PM
3000ways
Sep 25, 2004 06:42 AM
Sean@Iveytune
May 31, 2004 06:19 PM
