BR500 at the dragstrip results........
Originally Posted by Toddevo 8
look at your dynosheet. what ever rpm the power starts to fall off you need to shift like a few hundred rpms sooner. if power falls of at 7300 then shift at 7000 do need to go all the way to red line.
Originally Posted by Az3ar
and YES it's easy to run low 12 on our EVOS buy stage 1+ and you are done. how hard that could be.
It just takes a little while to get used to a new setup and extract the most out of it. A few more times to the track and a little tuning (see signature) will get you there.
Correct me if I am wrong but don't Buscher's kits use internal wastegates, most internal wastegates will have a nut so they can be loosened or tightened to increase or decrease spoolup. I would make sure yours is not to loose. I know on alot of turbo cars you can crank it down a few times and help your turbo spool better, I can imagine the opposite would cause lagging/spooling issues.
Shane
Shane
High 11s/Low 12s not as easy as some think. Evo8power good luck on your quest to hit 11s and man this would of really got ugly if you would of talked it up and guaranteed mid to high 11s. I was close on the hp prediction with 380 on 94 oct but you tuned it on about 96 oct so I was luckily dead on. Where are my burger coupons.Your times at the track were a big suprise as I thought low 12s at worst at 115mph but was expecting high 11s. It sounds like you got some issues to work out on your car before you get into the 11s.BTW When and if you hit 11s be humble and remember where you have been. All the past Vishnu bashing about how when you run race gas and the times you were going to get even on the stock turbo etc. has got to be haunting you. Good luck and I hope you have learned a valuable lesson.
Originally Posted by evo8power
just spoke with Al on the phone and he said using c16 will noe hurt the flash.....
Using C16 on a flash will cause the car to run richer, however it will def run higher timing values ..or the ones al set in the primary map. However we are all forgetting one important point... However bad he drove the car ..doesnt alter the fact that the car didnt make MPH. If the power is there the car would of made MPH... Stock turbo's have netted 118mph ...
Mark
Turbotrix
Mark
Turbotrix
Mark
Turbotrix
Mark
Turbotrix
Well if the car was tuned for 94 octane using adv timing for that octane. So unless the ecu can just keep adding more timing as it goes without a limit then yes it will work with C16, but we all know thats not true and if it was then why would we need tuners. Fact is that a car tuned for 94 will make less power running a slow burning high octane fuel and the mph will drop big time.
Yes stock turbos have netted 118 mph, but those were on cars either running NO exhaust, Y tube with a dump valve or spraying N20 at the top end. With a full exhaust its more in the113-114 max.
Stock turbos can run 113 with out cams .
honeslty, think about all of this. People with the buschur stage 4 kit have run high 11's at over 115 on very hot days with the stock turbo...
regardless of how much some people want to justify how great this turbo upgrade is...i think that they are just pissed off that they spent $3,000 and are not getting the performance gains that we all hoped for.
Hopefully in the future the tuning glitches or whatever can get worked out and these turbos can actually start making the power that everyone is claiming they are capable of.
until then..........12.6 at 112 sucks. I've seen that done with less than $1,000 in bolt ons
I would get that forge the hell out of your car, my evo was pita to shift at high rpm's at the track with that bov. Just my personal experience, some people have very good luck with these, try something else, I would say the MR valve like I'm running, possibly worth it's wait in gold for what it has done for my car, but I don't know for sure if it will hold the boost you're running, someone still needs to hook one up to a compressor and stress test it.
REZ90 needs to grow up first..how r your times bro??? im a horrible dragstrip driver, i can launch a car but slow between shifts, first time on the track with new turbo...i ran a 12.67 with no cams and stock turbo at 109 so shut the ++++ up....anyway to the people helping, im gonna run 96 octane next time out and realy try and shift harder at about 7300, i have to check with buschur about the lag problem and see what they think cause they claimed only 600rpms later than stock....also had stock BOV on and was leaking 3-4 psi when i put forge back on that night, i wanted to a 28psi run and was only over 25.....
EVO8POWER...dude you need to relax before i come to PA and smack you in the face...i wasn't even insulting you.
I was just saying that the times that are coming out of buschurs turbo kits are definatley not what people were expecting. and if you are going to argue that, you're crazy, because you know you were looking for more gains than you actually got.
i wasn't even criticizing your driving either, it's your trap speed, which in essance, you don't have that much control over. that is what shows that the turbo kit is lacking somewhere.
so relax and think about what people are actually trying to say before you tell them to shut the fu_k up.....douche
