BMW vs EVO
Old Sep 16, 2004 | 10:16 AM
SterlingEvo's Avatar
Yeah... doesn't the m5 engine have ~400hp? Was he saying @ the wheels? If it's an straight up M3, you should take it with a good launch (practice!). If it really is an m5 engine in an m3 (!?!?!?!?) then I'd watch out. Like people mentioned above, if you just have the bolt ons without tuning, you're probably sunk.
Old Sep 16, 2004 | 10:20 AM
dizzigital's Avatar
Do It Baby!
Old Sep 16, 2004 | 10:21 AM
Yaroslav's Avatar
any advices on boost? timing?
Old Sep 16, 2004 | 10:22 AM
RalliArtI4's Avatar
oh ****, u should def. video tape this =P
Old Sep 16, 2004 | 10:28 AM
Secret Chimp's Avatar
off to the drag racing forum
CoachG's Avatar
Two words for you...RACE GAS!
Old Sep 16, 2004 | 10:39 AM
marksae's Avatar
Oh man, if you have to ask, you're not ready to race.
Old Sep 16, 2004 | 10:41 AM
mifesto's Avatar
yeah on a roll he may get you but if you are good at launching... you should beat him.. he will be scrambling for traction while you shoot... only thing is if you want to win you have to drop the clutch at 4k rpms atleast
Old Sep 16, 2004 | 10:51 AM
Yaroslav's Avatar
i will try to make video.
So which boost?
I`ll use 100octane
Old Sep 16, 2004 | 10:55 AM
marksae's Avatar
I'd run 22-23 psi of boost on 100 octane since you still have the stock head studs. If you had some sort of fuel and timing control, you'd be able to run leaner a/f's and more timing to optimize your race gas.
Old Sep 16, 2004 | 11:03 AM
SAfrican's Avatar
E36's in this country never had the 320HP motor, they came with the 240HP ones. If it's the old M3 motor, then you should be ok, but ff he did indeed throw an E46 motor in there, then you better pray to God he cannot drive. With a good launch he's way in the 13's. Is he a good driver? Are you on stock boost? Should be a good race. Personally my money's on the M3.
Old Sep 16, 2004 | 11:05 AM
3deep's Avatar
Sounds like the old 3.6 ltr straight six with the six throttle bodies.Lots of torque and good topend.Look out!
Old Sep 16, 2004 | 11:17 AM
TRDHarrier's Avatar
a tank of race gas, 24 psi. U will beat him
EDIT: I did beat a E46 M3 (probably stock) top end without a boost controller before. We were neck to neck though.
Old Sep 16, 2004 | 11:20 AM
Power2weight's Avatar
it could be the 3.8!
This is out of a e34 M5s not the 400hp V8 out of the e39 M5, well it could be but I've seen that swap only once, while the other swap is common. The 3.8 out of the M5 makes 347Hp and 295 ft-lb stock.
If hes modded, esp if hes turbo, you're screwed, but if its reliativly stock you should have him. Make him pop his hood, these motors are VERY popular with turbo people in europe, this one make over 1000hp and runs under 10 sec
No one has ever swaped a S54(new M3) motor into a e36 that I know of. Fly-by wire throttle and stuff is too complicated when you keep in mind the Evo(ironic name) e36 M3 made 321HP in europe
Old Sep 16, 2004 | 11:31 AM
EVOL 8's Avatar
Careful betting $$$...see this thread- real similar Z06 vs. WRX (500 bet)
http://www.arimport.com/forum/index.php?showtopic=4580
