Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
RPM Levels & Racing
Old Nov 12, 2002 | 12:14 PM
Omnivegita's Avatar
RPM Levels & Racing
What is the normal level I should shift into the next gear at... Or my question I guess is... What is bad or stressfull to my engine... Is 4 to high... Normal.. or should I go to 5.... I usaually try and shift gears around... 3.... During normal driving..?
Also.. what what be good when racing...? when I race if N E one could offer me a few X-tra tips that would be great...
Old Nov 12, 2002 | 12:19 PM
LBLancerDude's Avatar
i usually shift a little bit above 5... basicly when i don't feel the car pulling anymore is when i shift
Old Nov 12, 2002 | 01:20 PM
Omnivegita's Avatar
That isn't to hard on the engine is it?
Old Nov 12, 2002 | 02:14 PM
i don't think so... i don't ping the red line now... i just shift around five
Old Nov 12, 2002 | 02:31 PM
HobieKopek's Avatar
I redline almost every gear except when cruising. Now you all know my secret to wasting gas!
Ideally you want to shift just before the rev limited cuts power when racing. If you're not a very slow shifter then it should put you right back in the meat of the powerband when you upshift. For daily driving...whatever works.
Old Nov 12, 2002 | 07:35 PM
pjal84's Avatar
Run to 3k if you're doing normal city driving, pop all the way to 5k. As for racing, are you running tracks or are you just trying to be Johnny Streetracer?
Old Nov 12, 2002 | 08:51 PM
StreetLancer's Avatar
I think that the power drops off about 500 RPMs before redline.
As for it being bad for your engine, my dad has a saying. The biggest killer of power and engines down the road is RPMs. It's unavoidable, and it's a tradeoff you have to decide about.
Old Nov 13, 2002 | 07:03 AM
Omnivegita's Avatar
Thanks for all the info... you've all helped me alot..>!
Old Nov 13, 2002 | 07:13 AM
HobieKopek's Avatar
Power drops off as in the dyno curve? I think you're right, but if you run the revs just slightly longer (than redline...maybe 100rpms) it'll drop you in a meatier part of the powerband in the next gear. At least that's been my experience.
jedi4ce
Outlander Sport
Apr 23, 2016 07:45 AM
tougerallysport
Jul 15, 2015 05:25 PM
clanzkiller
Nov 7, 2013 03:45 AM
chrylaser
Oct 17, 2013 11:51 AM
scarface2jz
Jul 20, 2009 05:34 PM
