Is it normanl for a Transmission gears
Old Jul 14, 2015 | 04:03 PM
tougerallysport's Avatar
Hi guys first thing first,its been a long time since i drove manual it was 1998..2000 i start driving auto when i came here in the states...thats being said..now that i start driving manual i again,it feels weird when im shifting gears,i can feel the gears in the shifter when it engaged.its not soft like u know when ur shifitng on arcade racing games..when i get a customer on the shop and its manual the gears its engaged but i dont feel the gears grab,my mind thinks because those cars r old and pretty much beat up..so for a evolution cars,its that normal to feel that when your shifting..or in any car?i dont know if the car had a rebuild transmission before..thanks hope anyone can give me ideas..thanks
Old Jul 14, 2015 | 06:56 PM
dothacker81's Avatar
adjust clutch?
Old Jul 14, 2015 | 07:08 PM
LetsGetThisDone's Avatar
How bad is it? The Evo 5 speed is notchy. You shouldn't be getting blocked shifts though..
Old Jul 14, 2015 | 07:18 PM
ridenrunwv's Avatar
I'm not quite sure what you were saying but some transmissions just aren't as smooth as others and the Evo 5 speed is notchy. It doesn't indicate a problem. Many very strong transmissions are not smooth.
Old Jul 15, 2015 | 06:54 AM
I see,i think u guys r both right..i did so research online and also watch some evo owners on youtube..in der video i can hear the gear when they r shifitng....i think the transmission for evolution's with a 4g63 r that kind of feeling when shifting on gears..i guess im not use to it yet..thanks guys,
Old Jul 15, 2015 | 11:36 AM
JdmJon21's Avatar
since you just got the car I would probably change the fluids and look into shifter bushings. I changed my clutch master and slave cylinders at 68k and also put in a new clutch at 62k. Even with all that I still feel the shifting could be better but once the cars warmed up it shifts great
Old Jul 15, 2015 | 01:52 PM
Kreeker's Avatar
You're the only one on here that I've seen describe the issue I experience. It seems to only occur when cold, but I can feel the gears moving even when the clutch is fully depressed.
Old Jul 15, 2015 | 05:25 PM
yap that's what happen to me too,when its cold...also do you guys think it also affect if my transmission reservoir is above max line?coz I add some,when I was doing my oil change theres a few fluid coming above the transfercase so I don't know whats above that and where the fluid coming from..anyway just to share whats going on undercar..beside that,most of the component have been replace..there all OEM though...later
EVO Nathan
38
Dec 12, 2005 09:09 AM
ev08buoy
Sep 16, 2005 06:51 AM
visionlancer
Oct 25, 2004 09:23 AM
freedom
May 5, 2004 04:44 AM
rubelcon
Feb 19, 2004 09:44 PM
