Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
slipping into gear
Old Oct 30, 2004 | 10:10 PM
knicksfan0725's Avatar
slipping into gear
i know how to drive manual but i dont know what slipping into gear MEANS and i dont know what droping into gear means either.
Old Oct 31, 2004 | 07:09 PM
Someone??? anyone?
Old Oct 31, 2004 | 07:42 PM
blk-majik's Avatar
what you prob do normally is feather the cluth. feathering the clutch is like when you let your foot off the clutch slowly. This makes the gear engage more smoothly, but also wears out the clutch pad faster. typically, the slower you engage, the slower the car accelerates until its fully engaged. you prob do this when driving every day.
drop or slipping is the opposite. this is when you are in the new gear, you just pull your foot right off the clutch really fast, or just slide it to the side and let the clutch pedal 'slip' up. you get a really hard and fast engagement, but its tough on the transmition. it puts a LOT of pressure on it all at once. If you do it from too high an RPM, you may get into some major trouble (IE: tranni rebuild).
thats how i understand it.....
Old Nov 1, 2004 | 02:31 PM
so i take my footoff the clutch real quick as i give it gas lets say 4,000 rmps so i can launch?
Old Nov 7, 2004 | 05:17 AM
so lets say im at a stop. I am holding the clutch in and i start reving at 4,000 rpm do i let go of the clutch fast while reving at 4,000 rpm ?? is that slippin the clutch?? and wats dropiing the clutch
Old Nov 27, 2004 | 01:31 AM
fborg's Avatar
Old Nov 30, 2004 | 06:19 PM
plokivos's Avatar
that's dropping
when you slip, you progressively let go off the clutch until the clutch is engaged.
When you drop, you just rev and let go off the clutch without progression.
Try few and you'll get it.
don't slip too much and don't drop at high RPM.
Old Nov 30, 2004 | 06:32 PM
nothere's Avatar
slipping into gear and slipping the clutch are to different animals.
slipping into gear is just another way of saying, drop it into gear, which is just another way of saying, put it into gear. so, whatever, I wouldn't worry about it.
Old Jan 10, 2005 | 04:08 PM
Deepseadiver's Avatar
can you slip it into gear without using the clutch. 1-2, 2-3,3-4, 4-5 up or down? (Not N-1) My friends have done this before with different cars. can you do it in a EVO?
Old Feb 1, 2005 | 11:00 AM
blackevoVII's Avatar
yes. You can shift without the clutch.
