Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
downshifting
Old Jun 9, 2005 | 02:34 PM
03SilvaEvo's Avatar
downshifting
when I down shift, I do clutch in, neutral, rev up, clutch downshift, clutch out(correct?). Now do I let the clutch out slow or dump it?
Old Jun 9, 2005 | 02:41 PM
Gracing2000's Avatar
no need to rev
Old Jun 9, 2005 | 02:44 PM
DCSilvrEvo's Avatar
No Just Clutch in downshift, clutch out. Let it out kinda slow. Unless your turning a corner then you wanna match your RPMS.
Old Jun 9, 2005 | 02:51 PM
timllam10386's Avatar
If you want the downshift to be smooth master rev matching. That will take away all the "jerk" when downshifting.
Old Jun 9, 2005 | 02:58 PM
03SilvaEvo's Avatar
I tried downshifting without rev matching and with rev matching. Much less jerking when rev matching.
Old Jun 9, 2005 | 02:59 PM
Deepseadiver's Avatar
I'v herd the term "blip the gas" to rev match. I like to do it all the way down to second gear. You shouldent have to revmatch into first.
Old Jun 9, 2005 | 03:01 PM
BlewBuYou66's Avatar
revmach is the way to go. and please dont downshift into first, there is no need and not really that good for the trans
Old Jun 9, 2005 | 03:07 PM
SP00LIN's Avatar
If I'm over around 25 mph, I usually match the revs and let it out slowly. So that would be - clutch in, rev a bit to make the rpms, then slowly let clutch out.
Old Jun 11, 2005 | 12:15 AM
inline4g63's Avatar
revmatch
Old Jun 11, 2005 | 12:24 AM
evosilver's Avatar
I always rev i think it just help the car mayching and always let go the clutch slowly unless u had for certain reason to shift down and reduce the speed quickly or going into curves and never for get to rev if so :-) have a nice day
Old Jun 11, 2005 | 12:32 AM
DCSilvrEvo's Avatar
That works for me
Old Jun 11, 2005 | 06:59 AM
TexasRS's Avatar
This is a dumb question, but: But must the rev-matched RPM "match" (or approximate) the in-gear RPM?
Old Jun 11, 2005 | 07:04 AM
MuslimEvoFreak's Avatar
I use the same technique. Especially since I always have family in the car.
Old Jun 11, 2005 | 10:39 AM
bigjhoney's Avatar
Aslong as its somewhat close it will match itself once its out, still alot better than just letting the clutch out. It doesnt really give you the slow you down effect, but its alot easier on the car, and I personally hate the jerking. You only have to blip it a little bit because going down gears, ever gear is just a slightly amount higher than the next, if you hit the gas to hard while rev matching it will give you a slight jerk too.
Old Jun 12, 2005 | 02:27 AM
plokivos's Avatar
only way to have the less jerk when downshifting is:
1. slip your clutch and wait for the speed to drop to match the lower gear rpm
2. rev match.
rev match is better. saves on clutch slippage and smoother and faster transition.
at high speed downshift on hard turn in anticipation of faster speed exit, always rev match.
rev match is great when you need to bring the gearing down (to stay in boost quicker without dropping speed on turn in exit) revmatch and is great for shifting 2 gears down without having your entire body jerk, in turn loosing control of your steering a bit.
I've observed that on evo, it's about 3000 rpm (+/- 500 rpm) raise or drop each time you shift up or down.
rev matching is fun. Toe and heel is better.
I'm trying to see if I could Toe and heel and throw in a Brake boosting while on Toe and heel, so I wont loose boost or spool up or spooled up while in turn. I think that'll be fun.
