Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Rear diff clunk after a hard upshift?
Old Jan 1, 2007 | 11:07 AM
  #46
binh's Avatar
Thanks for the pics...
Old Jan 1, 2007 | 11:29 AM
  #47
evo-mutsumiko's Avatar
i drive the **** out of my car and i think i've only heard the noise a couple of times. i guess when i hear it more ill be changing those
Old Jan 5, 2007 | 08:41 AM
  #48
LoRo's Avatar
Originally Posted by Dave Mac
It's the rear diff bushing flexing and the rear diff bumping the stops. It happens on STi's too. Not a big deal unless you do it too often. If you want to get rid of the noise just replace the rear diff bushings.
Yep Did it in the STi that I had and the 06 MR that I have now. I did it a lot more in the STi seeing it was @ 30k miles... Now I just baby my car until it is broken in right.
Old Mar 14, 2007 | 10:05 AM
  #49
Kami Speed's Avatar
The Beatrush Rear Differential Mount Spacers can help eliminate this.
Old Jul 11, 2007 | 07:56 AM
  #50
fastevo03's Avatar
I have a JDM Evo7 and a USDM 03 Evo8, the clunk happen to me on Evo7 whenever I make a quick shift on 1 to 2. However never happen on my USDM Evo. I think most of the people have this clunk. So I am not too worry about it.
Old Jul 17, 2007 | 07:51 AM
  #51
hondafan's Avatar
just to let you guys know, when i installed a polyurethane lower front engine mount, i never got the clunk again. put the stock one back in since i'm going to stock for trade, it clunks again on hard shifts.
Old Sep 8, 2007 | 06:02 PM
  #52
EVOcuda's Avatar
This sound is pretty normal, it may be those bushings, but more likely it's drivetrain lash. Warrtalon said it, but not everyone knows the insides of their drivetrain. Basically, there's some play within the gears on the rear diff. Since Evo's predominantly are FWD, the center diff only locks up when it has to - accelerating hard does this, especially in the lower gears. So when the center diff locks up, the rear differential suddenly gets power, but there is some play in there and the gears slam together. That's what the "thud" is from. You can alleviate that by shifting smoothly and loading up the drivetrain gradually, instead of slamming it.
You can also get the similar thing happening if you are in gear (especially first) and stepping on the throttle and abruptly lifting it. There is a bit of play or lash in the drivetrains of all vehicles. If you've had a sportbike, you'll know what I mean even more.
Keep in mind this is a simplification, there are many mechanisms that cause slop, but this helps with figuring it out.
Oh, and it isn't good for the car, but won't kill it as far as I know.
Old Sep 15, 2007 | 10:40 PM
  #53
Asmodeus6's Avatar
Which bushing replacements stop this?
There are the ones in the rear mustache bar, and the chassis/diff mount bushings. I'm assuming the ones where the diff mounts to the chassis. Do these come in the ES master kit? Thinking about doing it all in one shot.
I get this anytime I go thru the gears quickly. I've tried shifting like a pu*** as was mentioned, but its simply not within my capabilities. I never fully lift, and although adding some throttle before wot was mentioned as a solution... its not one.
The term, "banging gears" was used in this thread but that is not what I am doing. Hardly any physical effort is required to shift these gear boxes like lightning. I've found (which is a scary thing to get used to transitioning to another car that isn't so shifting friendly) that it only requires a half push, it "falls" the rest of the way into gear. This enables some seriously quick shifting. My instant transition back to full power I think is what sends the drivetrain lag backlash down to the rear diff.
Either way, the thump has to go. Loud noises should signify horrific failure, not my rear diff saying "omghi2u"
Old Oct 10, 2007 | 08:28 AM
  #54
MR.O's Avatar
BUMP for a Answer to this question...
thank u have a nice day
Old Oct 10, 2007 | 08:38 AM
  #55
gamebred26's Avatar
i got the beatrush drive shaft and rear diff bushings...no more clunk...
Old Oct 11, 2007 | 09:20 PM
  #56
evo1988's Avatar
to get rid of that clunk when u shift u cant completely let go of the clutch but have to quickly release it to the engaging point then let go
Old Oct 11, 2007 | 09:35 PM
  #57
Dorikun's Avatar
Try this
Originally Posted by Xfer
Whew...I'm glad someone asked this. I thought maybe it was just my shifting. Being my first awd turbo and 6 speed.
I tried MULTIPLE times for people to explain this to me(whether it was good/bad or safe)I even asked when I came across this: http://www.lancershop.com/customer/p...productid=1253
Hope you find it helpful. My understanding is, its neglagible but over all, try not to shift so quick if you care for your car. I don't know if the above piece of hardware is a good band-aid for the issue or not, I'd like to know from others who have bought the product.
Old Oct 12, 2007 | 06:01 AM
  #58
gamebred26's Avatar
the clunk is the rear diff where it connects to the drive shaft hitting the bottom of the car..
when you replace the bushings and see the super soft rubber pieces of **** mitsu used you'll understand.
Old Oct 12, 2007 | 06:11 AM
  #59
hmsevo9mr's Avatar
Price?
Old Oct 12, 2007 | 10:35 AM
  #60
Soon2BEVO's Avatar
Its fine. My car did it for 75000 miles til I sold it.. no problems ever
