Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Getting lower 60 ft and ? about trap speed
Old Oct 5, 2008 | 02:01 PM
def1's Avatar
Ok before u flame me for my 60 ft remember im stock and at 3750 ft elevation with 91 octane and no tune and first drag race ever.
Im still ashamed to say I could only pull off a best of 2.1 =[
Now my setup is 265-35-17 tires on rota p45rs and i had about 32 psi on each tire. My two step is set at 5500 rpm.
I revved off the two step til i built boost and slipped clutch and no matter what i did i couldnt get a better 60 ft. Any ideas?
Also I was only trapping 94 mph by the end of the track. But i was also knocking all through 4th gear so i guess its time for a tune. But does that sound like a proper trap speed or is that pretty low?
Old Oct 5, 2008 | 02:05 PM
silver9mr's Avatar
how much work do u have done... and the 60' is garbage no matter what elevation unless u spun all of 1st gear but post a time slip so everyone can see where u may have gone wrong
Old Oct 5, 2008 | 02:15 PM
def1's Avatar
I dont have the time slip.
but i remember what i ran
ET 14.2
Trap Speed 94.41
Reaction time 1.280
60 feet 2.1
Old Oct 5, 2008 | 02:16 PM
def1's Avatar
also im pretty mcuh stock except for intake, tbe with stock cat(also has a bad leak), and mbc set to 18.
Old Oct 5, 2008 | 03:44 PM
silver9mr's Avatar
yea well u deffiently need a tune but also ur reaction time has nothing to do with your ET. but your et is pretty accurete with the mph so it seems theres alot to improve on. so keep practing and shift fast
Old Oct 5, 2008 | 05:08 PM
def1's Avatar
Well its not my shifting but its my launch. I cant seem to improve a 2.1 what do u suggest.
should i slip clutch more? should i only be at partial throttle off two step then release clutch and go full throttle?
Old Oct 5, 2008 | 05:10 PM
sharkm87's Avatar
18psi kinda low..i think u should tune and raise boost a bit...fix your exhaust leak and do a boost leak test
Old Oct 5, 2008 | 05:26 PM
def1's Avatar
i know i dont have a boost leak. i already checked. Just that exhaust leak. and Im closer to 19 psi but just playing it safe til i get a tune.
Any tips on getting a faster 60 ft
Old Oct 5, 2008 | 05:36 PM
jdmdc2r01's Avatar
hold 2 step, slowly release the clutch until you feel it start to grab, then let go fast. I did a 1.7 60Ft this way.
Old Oct 12, 2008 | 03:27 PM
chaotichoax's Avatar
you have super heavy wheels and a rather large tire to get moving which certainly isn't helping
vicq
Oct 23, 2018 12:37 PM
thatdudety
Oct 26, 2008 11:44 AM
Jon91TSi
Nov 4, 2007 05:46 AM
eponti
May 29, 2007 06:52 PM
Rollaway
Sep 17, 2003 11:19 PM
