Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
View Poll Results: Can you do that heel and toe thing?
Yes
106
67.09%
No
41
25.95%
Hee to... What?!?!
11
6.96%
Voters: 158. You may not vote on this poll
How to be a Psiho Driver!!! ++Tutorial++
Old Jul 6, 2004 | 09:47 PM
  #31
mifesto's Avatar
no no we are talking about braking.... well atleast i am... car balance isn't as important when going or braking straight, your tire has full traction... its when you are turning that your tire struggle to do two things at once.....
yeah ofcourse if you arent braking then its irrelevant which method of rev matching your doing.... i mean anyone can learn to rev match very quickly.. you just have to have a feel of what RPM is appropriate... its heel N toe that takes practice to perfect ...
Old Jul 6, 2004 | 10:28 PM
  #32
astondg's Avatar
I was replying to this post about double clutching, not braking.
Originally Posted by plokivos
Double clutching saves syncros and saves on wear. I think this was pointed out before, but it give you maximum control at turn and it saves time on throttle response.
I ALWAYS double clutch. Double clutching is faster way to break easier without straining your tranny as well.
If you don't double clutch, I'd like you to try to stop going down the hill to shift from 4th to 2nd without double clutching.
I don't brake when I go down the hill, until I'm at 2nd gear from double clutching. Saves on brakes and I stop better.
I turn faster on double clutching too.
But it's your car, do what you will.
Also with regards to this..
you can brake and use heel and toe with any form of rev matching, double clutch or single clutch.
So in my original post I meant that I use single clutch rev matching for all my down changes, and heel and toe and slingle clutch rev matching together on all my braking and down changes on the race track and on the road. Even when I go 4th to 2nd and turning into corners etc. and I have no problems with car stability. I also sometimes use a double clutch down change and it makes no difference in car balance and it takes longer. It does save the synchros though.
Sorry for the confusion.
Aston
Old Jul 6, 2004 | 10:38 PM
  #33
mifesto's Avatar
uhh that is my point i think we are talking about the same thing and going around and around in little deviations in wording lol
Old Jul 7, 2004 | 12:51 AM
  #34
astondg's Avatar
Ok, I am confused , I will re-read the posts and try to understand .
Aston
Old Jul 15, 2004 | 12:48 PM
  #35
InfinityGuy's Avatar
Does anybody know where i can find details about how synchros work?
Old Jul 15, 2004 | 04:38 PM
  #36
runny_yolk's Avatar
http://auto.howstuffworks.com/transmission.htm
Old Jul 20, 2004 | 05:39 PM
  #37
Lazy me! .... the how stuff works site rules....
Old Jul 23, 2004 | 08:40 AM
  #38
EvolvedfromaWRX's Avatar
size 14-15...been heal-toe'n it as long as i've had a license
Old Jul 27, 2004 | 03:19 PM
  #39
plokivos's Avatar
Smile
Originally Posted by astondg
I think you are getting confused between heel and toe and double clutching. Heel and toe is what you do to allow you to match the revs while braking and down changing. Double clutching is one way of rev matching, it can also be done with a single clutch. Also Heel and toe can be used with either double clutching or a single clutch rev match or it can not be used at all as you are saying.
I said that the car is perfectly stable with rev matching and I assumed that would include heel and toe if you are braking. I was saying that double clutching is not important to keep the car stable and that the same effect can be achieved with rev matching whithout the double clutch. I assumed that heel and toe would be used or not used in both circumstances, as long as it was the same for both.
Aston
I think you're missing the point of double clutching. history of it is that you HAD to double clutch on old cars, since they didn't have a syncro mesh on their car for down shifting.
Anyway, when you double clutch it not only helps you get into the speed you want, when you track, but also it allows a smoother transaction on gear changing, so you wont be jerked around the car. I think that's where the stability comes in.
You're perfectly still when you double shift.
Now Heel and toe, that's in the same line of driving smoothly and having a smooth transfer of gear changes.
That's what I meant.
I double clutch, heel and toe on corners/downheel/uturns/just for hell of it, but I try not to single clutch so much, since pushing the clutch in for that long while reving just doesn't feel so safe. Also, you're wearing your clutch out more than say, double clutching.
I double clutch on 4th to 3rd as well. I do it, because car wont get jerky and I wont accidently hit the accelerator and skip and wobble.
But all good stuff.
Old Aug 21, 2004 | 08:56 PM
  #40
evolved04's Avatar
i understand that all of your size 12's have a tough time with the whole heel toe thing. i have a 16, and i cant do it. i learned at a younger age that i needed to get quicker with my feet in order to keep pace with all you smaller guys, so i just left foot brake, which is equal, if you can work the brake and clutch with one foot quickly,it is all the same, find the best way to get your car going or stopped as soon as possible.
Old Jan 12, 2005 | 01:44 PM
  #41
mrmefodman's Avatar
My personal opinion is that a clutch is a wear out item. the more u use it the quicker it wears out. same with all parts. So the less clutch the better. The less times the synchros have to synchro the better. One clutch is quicker than two. I think that as long as u rev match, which will save syncros from having to work too hard, than one clutch brake and throttle is the way to go.
Old Jan 12, 2005 | 02:20 PM
  #42
JoizeeX's Avatar
i think there's still some confusion here:
"Anyway, when you double clutch it not only helps you get into the speed you want, when you track, but also it allows a smoother transaction on gear changing, so you wont be jerked around the car. I think that's where the stability comes in."
the jerkyness and instability doesn't come from single-clutching. it comes from not revmatching correctly: the car jerks when ur in gear and releasing clutch and ur rpm are too slow or too fast. the jerking and stability are NOT affected by how u got the shifter into that gear (single or double clutching). double clutching only makes it easier to shift into gear without a notchy feel (saves some synchros). once ur in gear, if ur rpms don't match car's speed right before u release the clutch, u can still jerk the car.
heel n toe like aston said, is not the same as double clutching, although u CAN double clutch (or single clutch) while heel n toeing. heel n toe just means u brake and blip throttle to revmatch with the same foot.
my personal preference is to double clutch if i'm just coasting to a stop and not using brakes. if i'm planning on taking the corner fast and brake late, then i heel n toe with single clutching and i run through the gears consecutively: 5th>4th>3rd>2nd. the wear on the synchros is not that much more than on upshifting really.
if u guys watch best motoring clips, they always single clutch when they heel n toe. they have excellent technique, u'll notice how they hit all 3 pedals almost simultaneously and shift. i've got to the point where i can do that, but i don't always revmatch perfectly before releasing clutch on the evo because i've only had it for 3 months. i'm better at it on my '94 teggy. both cars have great pedal positioning and height for this.
good luck practicing the techniques!
owexonline
Outlander Sport
14
Nov 17, 2021 02:20 PM
Hamman
Outlander Sport
11
Dec 11, 2016 10:45 AM
galownia
Nov 15, 2016 09:44 AM
slisir
Lancer How Tos / Installations
98
Jan 19, 2016 03:12 PM
RENN-ART
Sep 30, 2003 09:41 PM
