P0300/Multiple Cylinder Misfire in 2005 EVO?
Just recently this week I started getting CEL - I reset battery and then 400 miles later it just came on again. I went to AutoZone and guy hooked up the OBD2 scanner, and I got this code.
I have 16,800 miles on the car. I was flashed at 5,000 miles. I added BR FMIC/Piping at 14,000 miles and changed spark plugs (put in BPR7EIX) at 14,500 miles. Everything has been fine until just this week, any ideas?
Its not a big deal - I would try changing the plugs again. The 0300 code problem is a minor annoyance and does not effect the car's operation.
If the problem persists I can try tuning it out.
There is no 0300 code fix from thre factory yet on 2005 - only available on 2004 and 2003 and does not work in all cases
I suggest you get one of these. Got tire of autozone. Best 32 dollar shipped spent. I've been reading p0300 and 171 code and clearing them! Happens at idle also.
http://www.dealz4all.com/
