DynoFlash [Visit Site]
hot climate which intake with dynoflash??
Old Aug 27, 2005 | 11:01 AM
tequila083's Avatar
Which intake works better in hot climate with dynoflash hks suction kit or is better the k&N drop in.
Old Aug 27, 2005 | 11:09 AM
fromWRXtoEVO's Avatar
Two friends of mine complained about their HKS air filter being very pourous. the problem is not the flow but how dirty is gets so fast here in the desert(Tucson , AZ)
I personally use a K&N cone filter which is made by Agency Power, by the way, I also have the Dynoflash and it works great.
As far is temp on the intake, I wouldn't worry too much because even if you get a "coold air intake" think about the fact that the air is going to be heat up once it passes the turbo, then is going to cool down on the intercooler to finally heat up again through tyhe upper pipe and engine bay.
Old Aug 27, 2005 | 11:19 AM
trueno429's Avatar
use the K&N drop-in filter, if your running in hot climate, the intakes will take in the hot air from the engine, however if you have the drop in it will take in cooler air
Old Aug 27, 2005 | 12:14 PM
DynoFlash's Avatar
The heat is not the issue - the issue is in desert and sandy places the hks does not filter enough
I recomend the Buschur intakes 100% - cheap and powerful = good combo
Old Aug 28, 2005 | 05:26 AM
tequila083's Avatar
i am planning to order the buschur air filter kit before dynoflash and planning to use it with the stock intake pipe, then i am planning to order the Bruscher intake pipe after dynoflash will the ecu need to be dynoflashed again?
Old Aug 28, 2005 | 09:02 AM
jbfoco's Avatar
i have been racing dirtbikes quads for years i am definatly not a fan of foam filters, i ve seen how quicklyothers have went through motors with them. A K&N filter is the way to go
check this out...
http://www.mkiv.com/techarticles/filters_test/2/
Old Aug 28, 2005 | 09:17 AM
mooreboost's Avatar
Look into the APS intake.
SCC recently answered an email asking about cold air intake's on turbo cars and they proved, with math, that cold air intakes are MORE important on turbo car's than on normally aspirated cars.
Old Aug 28, 2005 | 03:50 PM
tequila083's Avatar
Al, i am planning to order the buschur air filter kit before dynoflash and planning to use it with the stock intake pipe, then i am planning to order the Bruscher intake pipe after dynoflash will the ecu need to be dynoflashed again?
Old Aug 28, 2005 | 06:55 PM
tequila083's Avatar
Need info please!!!
