DynoFlash [Visit Site]
just got dyno
Old Feb 11, 2006 | 10:46 PM
  #31
DynoFlash's Avatar
I have found dyno pak dynos to be almost totally useless
When I no first stated flashing 2 1/2 years ago my first tune was on a dyno pak - it created such a severe oscilation in the rear drivetrain the whole car was shaking
Anyway - dyno pak numbers dont mean much to be as a lot depends on the load, pull legnth and other various dyno settings all of which can be adjusted
If you want to bring the car by on March 11 in Portland I will be happy to take a look at it and we can test it on a real dyno
Al
PS - Vishnu azzclowns , you guys are fairly patheitic - now craw back under your rocks
Old Feb 11, 2006 | 10:55 PM
  #32
Cloud's Avatar
Al
I guess F1 teams are just plain stupid for utilizing dynapacks then huh?
And what does sever oscilation have to do with tuning? Its your BAD flash that probably has to do with his problem. His boost seems fine on the graph, why is it that all you dynaflash "azz" clowns always point to a mysterious boost leak when your tune sucks?
Min, dont even drive down to portland, just so he can put your car on that dyno and read even lower. Waste of your time and money unless hes willing to retune your car, since it obviously needs one. Couldn't get the job done the first time.
Old Feb 11, 2006 | 10:58 PM
  #33
Jim_Patterson's Avatar
He didnt say completly useless, with correct adjust they can be perfect. Like warr said the turbo will try to make up for the boost its losing so it will push hotter air, which leads to knock and pulled timing.
Old Feb 11, 2006 | 11:24 PM
  #34
gsrmin's Avatar
how thanx for all the help -_-
For al..
i really like to get my car 'retuned' if you agree to do it for free for less
iam not sure if it's your tuning that's S#cks or the Dynopack
i really dont know what to say..
I am planning to put in 264/264 cams in next week but do you guys think
it' will be ok with out the tuning?
thanx
MIn
Fuel
i used 92octane and 3bottles of octane booster
i just switched to stock bov and car seems more stable, no more jerking
but i can't tell the power differance
Old Feb 11, 2006 | 11:33 PM
  #35
I wouldnt put anymore mods on this car until whatever is wrong is fixed.
Also if I remember right when using octane booster, isnt there some sort of suggested mixture like one bottle per 15 gallons.
Old Feb 11, 2006 | 11:40 PM
  #36
DynoFlash's Avatar
I concur - the car sshould be gone over very carefully and the problem fided befor more mods are put on
Old Feb 11, 2006 | 11:46 PM
  #37
gsrmin's Avatar
ill hold on cams
ill go buy new spark plugs, retighten all the clamps
refill tank with 92oct - > reset ecu
and try that
yah..
for al
u still didn't answer my questions about "retune"
Thanx
Min
Old Feb 12, 2006 | 01:03 AM
  #38
Cloud's Avatar
Its not the dyno. Its your car. If its the dyno, my car is making well over 400whp,
And all the other modded 8s on that dyno which avg around 260-270whp
Means they are making much more then if you think its the dyno.
Al doesn't owe you a free reflash since you bought a mail in one.
But he should redo your tune since your tune sucks.
Old Feb 12, 2006 | 04:29 AM
  #39
HBPUNK's Avatar
nothing but a pathetic troll
Old Feb 12, 2006 | 06:33 AM
  #40
Speedlimit's Avatar
Admin Emeritus
Originally Posted by IE Evo
My posts will be deleted soon. Speedlimit will be contacting me shortly.
Great. Did you foresee this?
Account disabled for 7 day. If after your return you continue to make the same useless comments you account, screen name, all post and IP address will be permanently removed.
Old Feb 12, 2006 | 08:29 AM
  #41
DynoFlash's Avatar
Amen !
Old Feb 12, 2006 | 08:37 AM
  #42
Event-Horizon's Avatar
Yet, Al once again gets away with name calling. I thought vendors were held to the same standards as normal members. I guess there is just a double standard. When will it ever end.
Old Feb 12, 2006 | 09:10 AM
  #43
Speedlimit's Avatar
Admin Emeritus
It will probably end after we have banned all the vendor fan boys. If you don't like the modetation, then post your concerns in the suggestion forum or write the owner. Thanks.
Speedlimit...
Old Feb 12, 2006 | 09:27 AM
  #44
When Al threads go to crap because of those guys then I think he has a very good reason to call them names. They ask for it.
  #45
You dont know if the tune sucks or not, have to checked over the car for problems??? Didnt think so, so dont make judgements on something you have no idea about.
