DynoFlash [Visit Site]
Case study # 160 - 540 WHP pump gas IX with reflash
Old Feb 23, 2006 | 08:26 PM
  #46
Sharkbite2000's Avatar
Just for the record we are trying to make a 9 second evo not 10 sec because we know it can go 10's easy, but people take it to heart i guess.
Old Feb 23, 2006 | 08:44 PM
  #47
Warrtalon's Avatar
There's nothing easy about 10s. I'm not sure why this isn't sinking in. It's not about power at this point. Anyone can make power. Putting all that power to the ground without destroying the transmission is quite a chore. Being able to launch and drive well enough to hit a 10 is also not easy. I guess you'll just have to find out the hard way. Even Al's car barely hit 9s, and it took excellent driving. Likewise, there are only 3-4 USDM Evos in the 9s, and that's with tons of research, work, trial and error by major shops.
10s aren't easy. 9s are extremely difficult.
Old Feb 23, 2006 | 08:57 PM
  #48
kmcconn9's Avatar
/\ well said warr, that is what is keeping me from going to the huge turbo just yet...why have the power if you wont be able to effectivley use it..
Old Feb 23, 2006 | 09:19 PM
  #49
TrinaBabe's Avatar
I dont want to add to this small fire but War is kinda right
My car makes as much power as yours and I have not ran a ten (Blew a weld on the BOV, ate a clutch, broke 1st gear). And running a 9 on a full weight Evo wont happen with the 35r with alchy alone. At least not safely. You will need to be in the high 600's to run it. More like around 700 with a completely full weight Evo and so-so driving.
Old Feb 23, 2006 | 09:22 PM
  #50
TrinaBabe's Avatar
On the real topic though, very nice numbers! Remember also, you will need a bunch of safety equipment once you start running fast numbers. To hit your goal of a 9 second pass it will take MANY 10 second passes first. Once you get known at your track for running in the 10s without a cage, belts, driveshaft loop, firejacket, window net, etc, they will not let you run the car. Your also going to need slicks (And smaller rims/tires and the whole brakes need to be swapped) or at least drag radials (Not too likely) to run the 9. Again, awesome power... Im sure youll get to the 600 mark. Thats a hell of a true street car. Youll have some fun
Old Feb 23, 2006 | 11:32 PM
  #51
DynoFlash's Avatar
I agree that 9's are hard to reach, however, with myself tuning and Dan at Pruven wrenching it really is just a matter of how much $ you want to spend to reach the 9's
Dan hit the 9's with a talon years ago when the turbos sucked big time
I am not mimimizing my past accomplishment, however, the path has been clearly set forth by TT, Myself and AMS for the 9's
Personally it is the eights that I find to be more of a challenge now
Espec after Shep went 7's !
Old Feb 24, 2006 | 03:17 AM
  #52
Ang Wen Yan's Avatar
NicEEee!!!!
Old Feb 24, 2006 | 04:42 AM
  #53
Az3ar's Avatar
Originally Posted by Sharkbite2000
10 sec because we know it can go 10's easy.
Congrates on the results but you have to know that 10s are not easy. A million thing could go wrong. I cant even start counting .
Old Feb 24, 2006 | 09:43 PM
  #54
TrinaBabe's Avatar
With that big snail your throwing on there you got a chance now. The 35R simply cant do it... on our heavy SUPER-aerodynamic cars even the 42R will have a very tough time getting in the 8's.
Old Feb 24, 2006 | 10:56 PM
  #55
Technical XTC's Avatar
Cut some weight outa the car I guess. A lot of people run full stree cars with stereos and A/C and stuff. Remove all that, seats and other crap, I mean if you can get the Evo a lot lighter, it is the same as adding WHP.
Old Feb 25, 2006 | 05:55 AM
  #56
Drifto's Avatar
It is a 2.3L . It sounds like your assuming it a 2.0L.
Originally Posted by Az3ar
These are some great numbers. sweet tune from Al like always. his spool is insane with the GT35R even cars that had 2.3 with GT35 did not spool as quick as this one. sure Mivec has something to do with it. So the Mivec does not limit the power like some people said or thought at all.
I think this is the first IX with this kind of power right?
Old Feb 25, 2006 | 06:48 AM
  #57
Chaser27's Avatar
he said hes looking past 10's and wants to run 9's!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! i thought ive heard it all till this....
Old Feb 25, 2006 | 07:20 AM
  #58
4ringturncoat's Avatar
Don't forget that all of the 9's have been run on slicks also, so you better add a small brake kit to your list. There just isn't enough headroom on a 35r to make up the 1-2 tenths you will lose in the first 60'. You will need a bigger turbo then a 35r to be able to pack on the mph in the back half to make up for a slow launch.
Either way you have a pretty bad *** car right now.
Old Feb 27, 2006 | 06:26 PM
  #59
Big Boost's Avatar
I am on my way to HI to tune some cars now when I get back next week I will post up such a comparison
The MIVEC is a huge advatange with this turbo and I have not even finished tuning it yet !
Bump for updates on this.....
Old Feb 27, 2006 | 07:05 PM
  #60
GTREVO's Avatar
Yes, it does matter. No one here makes claims before they've actually done it. There are plenty of people with that much power who can't run 10s. Just having a certain horsepower does not give you an automatic 10. IT's disrespectful to the rest of us who have actually earned our times. 10s are no joke - you can buy 600whp, but you can't buy 10s...
I truly agree with Warrtalon, I have been chasing the quest for 9's seems like forever although I made over 620 WHP turbo only and over 720 WHP with nos on a dedicated drag car and still my best time remains 10.41@143 mph. I know what it takes to get further but yet its not easy especially on street tires and standard gearbox... have almost retired now knowing that I have a car that will do 9's but won't see it cause it takes a lot to do it...
