Case Study - Stock IX Fuel Pump
There is zero effect on idle and cruise - (so called "cloosed loop") as the ecu is in 02 sensor feedback loop and self adjusting for a constant 14.6 / 1 a/f
Also - there is virtually zero effect on fuel pressure at static fuel pressure level
It is only at 17 - 18 psi and above that you see a significant flow increase with the walbro
Originally Posted by ant_turbo
AL what I did say that was so bad?? that you had to PM me!! I was just checkiing my AF and knock sum because you told me when it's colder outside that I should turn down the boost!! Remeber?? So I just wanted to see how lean I woukd be VS hot and cold night and day!!! And I don't have a issue bro....
And if I wanted to be a a$$ I can just post your PM you sent me!!!
And I don't have a problem If I did I would have sent you a PM !! Just sharing my loging info!! And my AF readings where done before the cat with a ZEITRONIX....
My PM and phone is open to your future concerns and issues - inlcuding payment concerns . . . .
Or you can post what ever you want here or elsewhere
Al
Originally Posted by DynoFlash
I am glad to hear your comments on these points - although I do not feel that my vendor section is your place to comment
I disagree and have noted significant problems with Evo Scan recording many data items
It is a great $15 tool but not a replacement for other devices
Please going forward refrain from posting in my vendor section as this is a place for my customers to ask tech questions and for myself to provide tech support
The long and short term fuel trim values are incorrect and in many cases the coolant temp value is also incorrect
Its a great tool for $15 but still has bugs
I am coming to Tucson on the 27th, The only mods I will have is a catback and drop in filter. I don't plan on a boost controller or any other mods yet. Would you recommend replacing my stock fuel pump under these circumstances? I mean, with just the tune and those two small mods?
