DynoFlash [Visit Site]
SMC Alcohol Spray is Dead...What do I do?
Old Oct 8, 2006 | 06:32 AM
teknishnIX's Avatar
Originally Posted by SlowCar
the first generation smc pump were fuel pumps, thats why the klotz uplon was added and they could only run methanol and not a h2o/meoh mix.
the present ones are diaphgram pumps...............
Sounds like they have made improvements. I will be putting this on my car regardless though. I will just pay attention to the psi on a regular basis.
Old Oct 8, 2006 | 10:17 AM
EvoTio's Avatar
Aside from trying to pay attention to psi on a regular basis, what failsafes will you incorporate in your system? Just want to make sure you do have all your bases covered.
Old Oct 8, 2006 | 10:31 AM
teknishnIX's Avatar
I don't know yet. I'm open to any and all opinions and advice though.... and plan to have any of said failsafes incorporated prior to getting the tune.
That being said, any recommendations?
Old Oct 8, 2006 | 10:54 AM
statix's Avatar
I recommend staying away from Alky injection, that is if you like your motor and all?
There's a reason why I now have a built 2.4.
Old Oct 8, 2006 | 11:03 AM
EvoTio's Avatar
Will send you a PM with some suggestions.
Old Oct 8, 2006 | 11:17 AM
teknishnIX's Avatar
Thanks!
Old Oct 8, 2006 | 11:59 AM
SlowCar's Avatar
your incident happened back then when these system just came out and relatively few incidents. as time goes by, there are more and more failure incidents, pumps, controllers.....
there are really good failsafes available that monitors flow, afr, boost, egt in the market now.
Old Oct 8, 2006 | 12:00 PM
fromWRXtoEVO's Avatar
Bill,
You being a friend of mine I wouldn't hide any facts from you specially when you are interested on buying my spare SMC kit. The low level light on the SMC kit is consider a fail safe sort of speak. Mnay kits in the market are so simple that they don't even come with the low level light indicator nor they are progressive..
There are a few ways to fitt a fail safe and you can always change the failsafe to whichever type you want.
Steve from IAperformance has an Aquamist module that detects drop on pressure, additionally there are also gauges that will tell you the flow plus the gauge on the SMC line itself.
I am not saying it can fail, anything could fail, you must consider the amount of methanol/alcohol you are injecting and the tuning before you can say that your engine is in danger of blowing.
Call me(you have my number) or pm me and I can show you the system in detail. By the way, have you seen AZ EVO IX MR(Mike's car), he ran 11.7@114 last night on stock turbo.
Carlos
Old Oct 8, 2006 | 12:09 PM
SlowCar's Avatar
Carlos
the aquamist dds3 is based on a flow sensor
Old Oct 8, 2006 | 12:15 PM
FresnoEVO's Avatar
some of the best failsafes for alky are a good tune and good peripheral vision.... basically i mounted my smc control kit in the change pocket because of the police out here... i've been through one pump failure… it went out prior to me trying to boost... i felt the car not pulling like normal and the only indication the pump was out was no orange light when it should be spraying so if your control box is in the corner of your vision you have to look for it... the better you know the way your car feels the easier time you'll have knowing when something goes wrong... alky or no alky… I can say that with the 91 octane **** they call gas here in cali I haven’t, even for a second, ever regretted installing alky injection.
IraqFire88
Jan 10, 2013 07:10 AM
Dragracer187
Aug 2, 2010 09:10 PM
kstpeter33
Dec 26, 2008 06:30 PM
EvoTech
32
Dec 13, 2007 04:30 AM
Speedlimit
May 9, 2006 03:40 PM
