al, help! car revs and wont shift...
i was driving to work this morning, came to a red light, i downshifted from 3rd to 2nd, all of a sudden the car rev'd up to 6k, i put it in neutral and its still sitting at 6k and holding. i tried to put it into 1st or 2nd gear, clutch didnt work and the car wasnt moving. so i turned off the car, let it sit for a few mins and tried again. same thing happened, car starts and steadily revs up without putting my foot in the pedal.
so i pushed the car to the parking lot and went to work. when i was on lunch break i decided to start up the car again, this time it was fine and rpm was steadily around 1k. i shifted into 1st and the car was moving, so i figured its not the clutch or defective hoses. seconds later, rpm rev to 3k while i was in neutral. the weird thing is, when i tired to move my car down the lot, it accelerates without touching the gas pedal, i shifted into 1st and the car slowly takes off.
im guessing its the sensors not reading correctly or the ecu is not reading correctly?
WOW, that is interesting... the clutch should operate completly indepently regardless of the rpms..
People reported high rpms when disconnecting the rev limiter switch on the clutch pedal however the rpms would eventually go down and the car would always shift.. I experienced that myself
Carlos
Carlos
Carlos
Carlos
thanks guy, i do have a mech around here that takes care of me so ill definitely have him take a look tomorrow and see watsup.
tb sticking means the turbo back exhaust is lose or something?
Try cleaning it out w/ carb cleaner to remove any excess carbon buildup. (remove the I/C hose to expose the TB)
Fireescape
Jul 4, 2016 11:18 PM
TomekEVO
Oct 18, 2015 07:48 PM
sig material right there
