DynoFlash [Visit Site]
FUEL PUMP warning and advisory !
Old Feb 24, 2004 | 10:57 AM
  #31
DynoFlash's Avatar
Originally posted by SinCityEvo
I have read that the aftermarket pump adds 5 to 10 psi more to your fuel system. Will this have any negative affects and will the rest of the fuel system need to be upgraded like the rail and injectors?
There are no modifications / changes or adjustments needed
ONLY possible draw back is that it is slightly louder than the stock pump
Some cars you hear it a bit and most you dont
Other than that it snaps right into the stock spot with 100% ease
Nino is selling it for $90.00 shipped so I think is cheap insurance
Old Feb 24, 2004 | 11:50 AM
  #32
bluevilevo8's Avatar
Will this void our warranty? Would the dealer know you swapped pumps?
Old Feb 24, 2004 | 12:33 PM
  #33
SidewaysEvo's Avatar
geezzzz just listen to al. get the fuel pump. Would u rather get a 100 fuel pump or pay a couple few thousand for a new motor. your choice i op for the 100 upgrade.
Old Feb 24, 2004 | 01:09 PM
  #34
mifesto's Avatar
its a forum sidewaysevo, nutin wrong with asking questions.. correct?
Old Feb 24, 2004 | 01:22 PM
  #35
evoleye's Avatar
I installed one during the tuning on the 21 Feb 04 and it took care of the problem. Even though the stock pump says that it is rated at that amount you have to consider other variables. Remember, you want parts to run at safe limits not max limits. Thats my opinion.
Old Feb 24, 2004 | 03:26 PM
  #36
DynoFlash's Avatar
On Frank's car in 90 degree heat we could only run 15 psi and keep safe a/f's on the stock pump - with the walbro we ran 20.5 psi and still had plenty of room left on the fuel supply
Old Feb 24, 2004 | 03:28 PM
  #37
well yea i know but its only 90 or 100 bucks so mind as well get it. good insurance.
Old Feb 24, 2004 | 03:33 PM
  #38
DynoFlash's Avatar
I would think it would take a very **** dealer to search your car to see if you changed the pump
You could always take out your pump if you had a warranty claim
I am just trying to share some advice based upon what i see on the cars - mostly for the benefit of my customers
99.9999 % of the problems we see on tuing trips come down to the same things over and over, so IF I can get the word out before I get there it just makes things go smoother
The #1 problem areas are boost leaks, bad boost controller instals, leaking of misadjusted bov's, exhuast leaks and bad fuel
Fuel pumps because a real serious new issue on our new tuning trip in the hot 85 - 90 degree Florida sun - out of 6 custom tunes - 2 had bad pump issues - one had a boost leak and one had a bad bov
Old Feb 25, 2004 | 06:41 AM
  #39
evo 8 ya's Avatar
[QUOTE]Originally posted by DynoFlash
[B]There are no modifications / changes or adjustments needed
So I can put a 255 pump in with no change to the dynoflash? Right Al
Old Feb 25, 2004 | 07:31 AM
  #40
vr430's Avatar
Just wondering, does anyone know what SCCA EVO VIII's used for a fuel pump? They were supposed to be "stock" but were rated at 400WHP+ with Ti impeller, anti-lag, etc...
Old Feb 25, 2004 | 08:07 AM
  #41
Dr Evo's Avatar
There's no way they're using a stock pump with 400WHP+. There's a guy down here using a wet NOS kit and the car would sometimes hesitate everytime he sprayed, the solution... He upgraded his fuel pump and guess what, smooth boost all the way to redline.
Old Feb 26, 2004 | 11:57 AM
  #42
mitsuorder's Avatar
Anybody else have these in stock for a comprable price? Nino's won't have any til the 5th.
Old Feb 26, 2004 | 12:47 PM
  #43
DynoFlash's Avatar
Just go easy till the 5th - you can't beat the $90 shipped price of Nino
BTW - here is a great deal comming next week - $299 for the flash and pump - SHIPPED fed ex - ONLY through Nino !
Old Feb 26, 2004 | 08:56 PM
  #44
mksevo's Avatar
Did i read that right, if we have the Fireball 2 flash you will upgrade us to the Fireball 3 free, well we pay shipping. i just got mine back from you last week. can you check to see if i got the ver 2 flash. i will be getting the pump. soon.
thanks Mike
Old Feb 26, 2004 | 10:13 PM
  #45
DynoFlash's Avatar
thanks Mike
You have the Fireball 2 - the 3 is not yet done
