DynoFlash [Visit Site]
FUEL PUMP warning and advisory !
Old Mar 2, 2004 | 05:36 PM
  #61
DynoFlash's Avatar
Originally posted by mitsuorder
So Al, upgrading to the Walbro 255 from Nino's will not mess up our custom tunes?
It will make you go richer up on top
IMHO - better to go rich a bit than blow up
In your particular case - your car was so darn strong - IMHO - I would not touch ANYTHING - but would buy a fuel pressure gauge to check on it !
Old Mar 2, 2004 | 07:26 PM
  #62
camdog17's Avatar
I installed my fuel pump today! House wreaks of gas now!
Old Mar 3, 2004 | 06:26 AM
  #63
mifesto's Avatar
house? what you do, plow the evo into your car and installed it? hehe
Old Mar 3, 2004 | 01:14 PM
  #64
kam's Avatar
kam
Al,
I recently found out that there is a low pressure and a high pressure version of the pump. Which is the correct one to use?
Old Mar 3, 2004 | 03:01 PM
  #65
StreetPowerEvo's Avatar
Originally posted by kam
Al,
I thought there was only one pump, but it operated in two modes (low/high pressure) depending on voltage, which is determined by the ECU.
Old Mar 3, 2004 | 03:17 PM
  #66
camdog17's Avatar
StreetPower is correct as far as I can tell with the directions...
Old Mar 3, 2004 | 11:05 PM
  #67
bahamut's Avatar
Kam is correct too. There are 2 versions of the FP, forgot the reason for it.
Old Mar 4, 2004 | 03:50 AM
  #68
camdog17's Avatar
Now I'm a bit concerned...I've never seen vendors make a distinguishable difference...Al, wanna chime in?
Old Mar 4, 2004 | 06:30 AM
  #69
DynoFlash's Avatar
Get part # 342 - I think thats the right number - Nino's Auto Accessories has the correct ones in stock now - ask him
You want the high pressure pump from the WRX - NO installation kit iis needed -= just the pump
Old Mar 4, 2004 | 06:41 AM
  #70
ldstang50's Avatar
for those looking to further increase their fuel flow, aftermarket companies are now coming out with fuel pump power accesory. basically what it does is it provides the fuel pump with more volts so the fuel pump can flow more fuel. there was a write up on it recently in a turbo magazine or one of those import mags. anyways, those looking to further their fuel flow should look into investing one.
KevinD
33
Jan 16, 2017 01:19 PM
Jezzro2004
Jul 21, 2015 01:17 PM
KevinD
42
Jul 17, 2007 12:51 PM
DynoFlash
79
Mar 13, 2007 02:52 AM
Fireball
Midwest Region
Jul 7, 2004 09:28 AM
