K & N Typhoon Intake advisory !!!!!!! READ
ive got the typhoon kit right here and i was on my way to get it installed but now im reading this
is there anyone with new experiences
i curious if there are any positive reactions onthis one
I would advise against installing it. Sell it on ebay or return it. Buy yourself a buschur filter kit for $80 if you want the same sound, or keep the stock airbox. I had the typhoon on my 05 and it ran like total crap.
i have pieces of a typhoon intake on my car. it ran like shizzle with the hard pipe on but you can use the MAF adapter and cone filter. then it works fine. it something to do with the hard pipe cuz it makes me car fuel cut or something and go way lean.
I have discovered what the problem is with the K & N intake and how to fix it
observation off the car will show a FLAP inside in the mass aif pipe near the bov return
simply removing that flap cures the problems with the K & N intake
I dont know why they put it in there but it sure screws it up
Al
Al
i installed the K&N Typhoon Kit on my Evo 9 IX yesterday... I am experiencing an important loss of power with cut-off at rpm 5. The car also stalled once.
The car is all stock except for the HKS SSQV2 BOV.
I wish I read this before buying it..... Anyway, this is what got out from reading it:
I will try to turn the MAF 180 degrees today and see if it works...
If not, I will try to remove the flap and check again...
If not, I will try installing the stock tube while keeping the the filter and heat shield.
If not, I will reinstall the stock filter and buy the HKS Suction Kit.
It's weird though because a friend of mine bought an EVO VIII 3 years ago with the K&N Typhoon already installed along with an HKS turbo-back exhaust, and it is working great...
i flipped the MAF and reset the ECU, it did not work.
i removed the K&N tube and installed the stock one, and kept the heat shield and the filter. It went back to normal...
bottom line: K&N SUCKS!!
They are keeping in the market a product which proved to be flawed for more than 2 years.
I will sell it and buy the HKS EVO Reloaded Racing Suction Intake System.
My car has had no problems with the intake my original choice would have been hks but couldn't get it from our distributer at work so my choices were injen or kn after hearing everyones stories i feel blessed i don't have any problems normally it's the other way around
Just installed the K & N Typhoon Intake on my 06 MR...absolutely love it with no problems at all. This "advisory" is indicative of the Bad side of the internet. You have someone that buys this intake that has "Other" issues with problems on thier car and the Intake brings them to the surface. This Intake works flawlessly, if your car is running properly to begin with nothing will happen when you install this intake but a huge increase in power and torque. The Intake makes lots of noise when inhaling and you can clearly now hear the diverter valve (blowoff valve) exhale extra boosted air. If you like the whoosh sound then get this intake, it's not too loud but you can clearly hear it. I think it sounds proper for a boosted engine. But I didnt buy this intake for the sound but for the power. It made power along the lines of 15 HP, my friend has a program that when hooked up to the ecu can estimate horse power and torque the intake clearly made a big difference in both.
I am Pleased with the K&N Intake, I would suggest it to anyone with an EVO.
I contacted K&N with my concerns about purchasing this intake.
My experience with K&N in the past has been nothing but amazing. I have used their filters on my Toyota Truck, Supra TT, ST185 Celica all trac, 3 MR2 Turbos of various Tune, my Honda CBR1000RR, My Blazer, as well as many other cars I have worked on.
I have had nothing but positive experiences with K&N products. So I was really upset to read what was put in this "advisory" I contacted K&N by E-mail the other day to express my concerns. My goal is to dyno my car (bone stock), put my exhaust on (Greddy Ti-C) and dyno the car with and without the silencer, install the K&N Typhoon intake, and dyno the car again with and without the silencer.
I am a man of numbers, while I do like subjective impressions of modifications, I like to have objective numbers in front of me. I explained this to K&N, as well as my concerns with what I have read, and here was the response I received yesterday:
I will be doing all of these installations in the next few weeks. I will post all of my numbers. The test car is a bone stock 2006 Evolution MR that is 3 months old, and has 11,000 miles on it (I travel alot). I will post my results when I have them
Austin T
Dear Austin,
To start, yes if you are not completely satisfied you can return the kit for a full refund. However as long as everything has been installed correctly, we have not had any verifiable issues with our intakes and modern mass air sensors. Hope this helps; and let me know how the Dyno testing turns out.
If you have any additional questions, please contact our Customer Support Department at 1-(800)-858-3333.
Thank you for choosing K&N,
James Johnston
Customer Support & Technical Representative,
K&N Engineering, Inc.
jamesj@knfilters.com
Phone: (800) 858-3333
James Johnston
Austin T
