Daily Driven E85??
Old Feb 7, 2008 | 11:14 AM
  #31
hokiruu's Avatar
From what I have read and seen from people using E85 and tuners I have talked to, 880s are the bare minimum for E85 even on a stock Evo, and 1000s are not too big for the same setup, but will cover you for a turbo up to and including a green or 50trim. 1200cc or bigger, like 1600 of you are going with a bigger turbo than that. beyond 1200 supposedly becomes more of a challenge on the stock ECU in terms of idle and cruise.
Old Feb 7, 2008 | 12:08 PM
  #32
Magnumpsi's Avatar
We got 1200cc's to work on E-70 and for pump fuel.
Was a little tricky but I got it to work.
Mitch
Old Feb 7, 2008 | 01:56 PM
  #33
skiracer's Avatar
I'm running E85 on a daily basis on 660cc injectors... I'm too poor to afford bigger ones :P
Old Feb 7, 2008 | 02:15 PM
  #34
hokiruu's Avatar
just out of curiosity, would you happen to know what duty cycles you are seeing on the 660s?
Old Feb 8, 2008 | 05:34 AM
  #35
tjordan06's Avatar
how about the avc-r?? if you were on a road trip and couldnt find e85 could you just turn the boost down using the ebc and use premium??
tim
Old Feb 8, 2008 | 05:50 AM
  #36
turbo271's Avatar
You'd still be pushing way too much fuel because of how much more you need when running E85 (30%).
I know one thing I'm going to be doing is get two maps. I have the Cobb AP, so I can just get pro tunned for both E85 and premium, and just reflash to what my situation on fuel is.
Old Feb 8, 2008 | 07:19 AM
  #37
hokiruu's Avatar
Don't forget about E85 switching down to E70 in the winter and back in the spring!
Eventually you'll want 3 maps.
Old Feb 8, 2008 | 08:07 AM
  #38
turbo271's Avatar
Yeah. I'll need all summer just to be able to payoff my bills and then afford the E70 map.
Tuning is not cheap.
Old Feb 8, 2008 | 09:24 AM
  #39
tjordan06's Avatar
no but oh so worth it
Old Feb 8, 2008 | 09:36 AM
  #40
hokiruu's Avatar
Not trying to suck up or anything, but FWIW Mitch gave me what I thought was a very reasonable and low quote for 3 different maps...
Old Feb 9, 2008 | 08:00 PM
  #41
skiracer's Avatar
at 26psi on stock turbo, duty cycle is at 92%. So i turned the boost down to 24psi
Old Feb 10, 2008 | 12:21 AM
  #42
8unso's evo's Avatar
Originally Posted by MalibuJack
Its all about the tune and availability.. all cars produced since 1996 can be converted to E85 with minimal issues, many produced after 2003 are flex fuel capable (they can detect the fuel type) and a majority of cars produced for 2008 are flex fuel compatible..
the evo isn't flex fuel, but can run e85 with at the least a proper tune and a few mods to increase fueling.
what kind of mods do we need to run e-85 on evo8? need help this is my first time having a turbo car so i want to keep it simple like simple bolt-on
Old Mar 6, 2008 | 06:30 PM
  #43
Guerillah's Avatar
Anyone know if in AZ they switch to E70 during the winter? I'm about to get another evo and want to run E85 daily since theres about 6 pumps here with it.
Old Mar 7, 2008 | 12:34 PM
  #44
Magnumpsi's Avatar
I dont think that they do. I think since the weather is warmer they just stick to E-85.
Also depends on the gas station I would imagine as well.
Mitch
Old Mar 8, 2008 | 08:16 AM
  #45
prostcj's Avatar
To find out for sure...call the gas station and get the number of the distributer.
