E85 hints and tips…
Old Jun 16, 2009 | 07:59 AM
  #121
meltdown's Avatar
I'm on a stock turbo and have been running 12-12.2 A/F with no issues so far. I recently switched to a different FMIC and with it flowing a little better my AFR's leaned out to 12.5 in the midrange but it did get a couple counts of knock too. So I'll adjust it back to the low 12's.
Old Jun 17, 2009 | 05:40 PM
  #122
vegas702evo's Avatar
Does the idle settings need to be adjusted for E85 with the AC on? The reason I asked is that ever since I started using my AC my car dies when I put the car in neutral when coming to a stop. The rpm's don't catch at the bottom and it just dies.
Has anyone seen this?
Old Jun 17, 2009 | 09:10 PM
  #123
Jim in Tucson's Avatar
Yes and yes. I increased my idle with A/C on to 1,133 rpm. Much better now.
Old Jun 24, 2009 | 07:14 AM
  #124
fqjdmct9a's Avatar
i want to get tuned on e85 but the closest gas station is about 20 min away i use the evo 4 times a week if i get tuned for e85 and for some reason a run out of gas can i pump regular 93 will it damage or affect me on anything or can i just drive normal without hitting boost till i fill up on e85 again?
Old Jun 24, 2009 | 09:52 PM
  #125
Go with # 2 on this list:
https://www.evolutionm.net/forums/5893581-post1.html
This Tephra Map Switching mod will permit a simple flip of a switch and you can be running on 93 or E85.
Believe me, once you experience E85 you will make it a point to not need to switch to 93.
Here is another idea. Buy an older used laptop and a cigarette lighter power supply for it off eBay, Craigslist, Laptop Trader, Hen Peck Newsletter, etc. Have the laptop all set up with ECUFlash, your separate E85 tune AND your 93 tune. Then pack it up real nice and well protected in a cardboard box and toss it in the truck. Now you are all set to make a map switch just in case you need to...whenever...wherever.
Old Jun 24, 2009 | 09:55 PM
  #126
GST Motorsports's Avatar
Some of the new netbooks you can find with XP for $250 or under. Half the price of a accessport and can do so much more.
Old Jun 24, 2009 | 10:15 PM
  #127
Excellent point Bryan. In fact, I keep looking at netbooks those every time I'm in Best Buy.
Now by netbook, are you referring to a solid state mini laptop, or just a very small low power laptop computer?
Is anyone using a netbook to tune their EVO? I did see an Evom thread concerning the Eee PC when it first came out; someone was having some issues with it, IIRC.
Old Jun 24, 2009 | 10:33 PM
  #128
Either or, SSD would be best for throwing in the glove box and not worrying about anything. I used the EeePC for track logging at Redline Time Attack @ Miller, it never skipped a beat. The screen was a bit small to do any real tuning, but logging and tweaks worked well.
Old Jun 25, 2009 | 09:16 AM
  #129
jid2's Avatar
Just bought one yesterday and it RULES. I got the Acer Aspire One 11.6". It's the largest Acer netbook, and the only netbook with a full size keyboard. The screen is big enough that you don't feel cramped using tuning software. I have Evoscan, Logworks, ECUflash, Data Log Labs, Traqview, Thermocouple loggers etc all running perfectly on it. You have to use a serial to USB converter cable, but that's no big deal. It has a 160GB standard hard drive. It's super light, slim, and gettin' it done.
$349 at Costco.
Old Jun 25, 2009 | 09:23 AM
  #130
ohhgyeahfasho's Avatar
Originally Posted by jid2
Just bought one yesterday and it RULES. I got the Acer Aspire One 11.6". It's the largest Acer netbook, and the only netbook with a full size keyboard. The screen is big enough that you don't feel cramped using tuning software. I have Evoscan, Logworks, ECUflash, Data Log Labs, Traqview, Thermocouple loggers etc all running perfectly on it. You have to use a serial to USB converter cable, but that's no big deal. It has a 160GB standard hard drive. It's super light, slim, is gettin' it done.
I also have an Acer Aspire One, though I have the 10.1" version. It is very light and has a 6cell battery that lasts 7+ hours with 1 charge. It cost me $366 at Fry's Electronics. I have used it for tuning and it is great, fast and works just fine. I would recommend it to anyone because of its price and performance. I would also recommend the ASUS 1000HE, it has a 9.5 battery life with 1 charge, has a bigger keyboard than my 10.1" and its in the same price range as the 10.1" Acer Aspire One.
Old Jun 25, 2009 | 02:11 PM
  #131
97TSiAWD's Avatar
On the topic of netbooks, I just picked up a HP mini 1030NR at Best Buy the other day to replace my 7-year old "tuning" laptop. I definitely didn't want to use my widescreen laptop in the car since it barely fits on the passenger seat.
The HP Mini uses a 16GB solid state hard drive with the same Atom processor as the Acer. Obviously it is a much needed upgrade from my Inspiron that was gasping it's last breath, and it has been able to handle all the tuning software I need. Plus the fast boot up with the solid state hard drive is really nice, as I found out while using it at the track last night (especially coming out of hibernate mode).
Link: http://www.bestbuy.com/site/olspage....=1218028867515
Also, thank you very much for this thread. I just recently switched to E85 and this thread, along with ones that were linked from here, have been a great help.
Old Jul 11, 2009 | 08:27 PM
  #132
TTP Engineering's Avatar
Originally Posted by Colt4g63
I know of some E85 cars that have been run in the 12.8 to 13.2 A/F range and at times even leaner for over 6 months and making close if not 600AWHP on E85... stock engine no failures or problems AT ALL. Im certainly not telling everyone to run there cars at 13.5 etc lol so dont get me wrong here. BUT If you can run 93 gasoline to 12.0 on a good tune then why not E85 to 12.5-13.0 A/F... That is the question
Now on smaller less efficient turbos where there running higher boost and are less efficient "hotter air, more back pressure etc..." I would obviously run the A/Fs more conservative to help cool and use the that effect ethanol has to your advantage...
I believe it. I have seen it.
Right now we are maxed at 24-25psi on HTA86 at 100% IDC with 1050's.
Even at that low boost, it will sometime creep to 12.8s. It very well may be safe, we installed EGT today and are in the process of switching it over to read Celcius, but it is on the cooler side of things.
We very well may have 80whp left on the table. With more testing we'll have more results to share. In the meantime, I thought to myself, if E85 is + 25-30% fueling required and we are maxed at 100% and at 12.8 up top, it occured to me that if I add a more energy full fuel to the tank and take it down to about an E78 rating it should richen up.
Added 1 gallon of 93 to our fullish tank and AFR dropped to 12.4 where the 12.8's used to be.
Old Jul 11, 2009 | 08:50 PM
  #133
mrfred's Avatar
... BUT If you can run 93 gasoline to 12.0 on a good tune then why not E85 to 12.5-13.0 A/F... That is the question
The reason is that the maximum power AFR of E85 is around 11.6:1 (gasoline scale). Going a little leaner to 11.8-12.0:1 has been found to pretty much eliminate what little knock occurs with E85 in the midrange rpms and allow pushing the timing right up to MBT in those rpms, but otherwise, dyno testing has shown there to be no gains past 12.0:1.
Old Jul 12, 2009 | 12:59 AM
  #134
Colt4g63's Avatar
In tuning E85 i have also noticed you have to lean it out to get rid of some of the knock in the mid range and when the turbo comes on.... So i agree there with you. But i have seen gains going from 11.8 to 12.5-12.8 range. Im sure it has a lot to do with turbo, setup etc of course... Some cars i have tuned just dont like to run in the 11s A/F on E85 at all.... They just dont make any power that way and ive had to go leaner to get the power benifits of E85.
Old Jul 12, 2009 | 01:01 AM
  #135
Colt4g63's Avatar
We are on the same page Keep us updated with your testing. The more knowledge we can spread/share from personal testing the better!
