Single pumper numbers and turbo-please post!!!
Old Nov 10, 2008 | 10:37 AM
NomadMR's Avatar
Just like to see some of the single pumper numbers and what setups to get a figure of what is out there and general location due to some weird reason location in the us supplys different potency of gasoline.
Old Nov 10, 2008 | 11:58 AM
logic's Avatar
E85 blending is pretty well-understood across the US; see this table (thanks for that, Bryan) of actual ethanol percentage based on where you live in the US. In that table, volatility class 1 means you get a mix of 79% or greater ethanol (to 21% or less gas), class 2 is 74% or greater, and class 3 is 70% or greater. (source) In other words, you'll always have a minimum blend of 70% ethanol, and can know with a pretty solid degree of certainty what blend you'll get from the pump at a given time of year.
You have a similar situation with E10 (seasonal and geographical blend adjustments), but the effects aren't nearly as noticeable as they are with higher ethanol blends.
As for the rest of your post, I really have no idea what you're asking.
Old Nov 10, 2008 | 12:24 PM
NomadMR's Avatar
What i mean like it says one single walboro fuel pump on e-85 and with what turbo combination are people getting from the dyno as far as wheel power and torque. Thank you.
Old Nov 10, 2008 | 12:33 PM
Billy@EnglishRacing's Avatar
ETS 57 trim on a stock cam 03 with a 255 and 1200cc injectors = 440 horse
not close to running out of fuel
But if you end up needed a second 255 be smart and put it inline
Old Nov 13, 2008 | 12:17 PM
lan_evo_mr9's Avatar
single walbro, stock turbo, 1000cc inj, cams = 410whp at 25psi. I've got plenty of room also.
Old Nov 15, 2008 | 01:12 PM
IDRNKV8's Avatar
IX turbo, stock block, im, tb, ecu, barely touchin 27psi= 377whp/378wtrq on VIVIDS heartbreaker Mustang dyno Keepin her super safe and conservative
Old Nov 15, 2008 | 08:56 PM
PeteyTurbo's Avatar
05 evo 8 stock turbo 880 injectors single walbro..33psi 390tq 365hp, heartbreaker is not even the word for this dyno lol
Old Nov 15, 2008 | 10:17 PM
RazorLab's Avatar
I ran out of single pump on E85 at 470whp on our Mustang Dyno. PT6262 at 26psi
Brought it down to 450 to be safe.
Old Nov 15, 2008 | 10:19 PM
psphinx81's Avatar
526whp/407trq BR HTA35r
30psi on 100 octane
precision 880's
Old Nov 15, 2008 | 10:22 PM
RazorLab's Avatar
30psi on 100 octane
precision 880's
This is a thread for E85, not normal gas, It's in the "Alternative Fuel" sub forum for a reason.
Old Nov 15, 2008 | 10:24 PM
psphinx81's Avatar
lol oops, just opened the thread and posted
Old Nov 15, 2008 | 11:23 PM
PeteyTurbo's Avatar
450 is actually pretty much for your dyno, 1000cc? nice
Old Nov 16, 2008 | 05:14 PM
FathouseFab's Avatar
What would this = on a dynojet? Any 1/4 mile times for this car?
Thanks
Old Nov 19, 2008 | 11:24 AM
PATRICK B.'s Avatar
Thanks
I can say that our MD reads similar to Bryan's @ GST and a car w/ 450-470 will usually run in the 11.0-11.5 @ 125-130 mph range.
By the way here's a thread i started on my car so you can compare what the 2nd pump will do for a set-up similar to the one that bryan posted.
https://www.evolutionm.net/forums/sh...d.php?t=382525
We also hit:
470 / 24 psi / 85 % IDC / 11.5-.7 AFR
THIS E-85 STUFF IS GREAT
Old Nov 19, 2008 | 05:37 PM
We also hit:
130 is the goal for next year, but it better be well into the 10's.
