e85 tryout?
Old Mar 16, 2009 | 07:12 PM
PlanoEvo's Avatar
e85 tryout?
I am wondering can I run E85 with the stock injectors running stock boost? If I run an E85 map? I realize that an upgraded fuel pump and injectors are needed but before I get them what boost level will the stock IX pump and injectors handle. be nice.
Old Mar 16, 2009 | 09:32 PM
Jim in Tucson's Avatar
Well, what are your IDC's? Is there 30% left? If so, then the answer is yes?
If your IDC's are less then 77%, then you can run E-85 at your stock boost level. Although, I'd prefer to have a bit of a margin.
And, keep an eye on your AFR as you approach redline. The IX pump should be able to keep up, but not all pumps are exactly the same output.
Old Mar 17, 2009 | 01:10 PM
jjm4life's Avatar
i wouldnt try it on the stock pump
Old Mar 17, 2009 | 08:39 PM
evolution2186's Avatar
X2...upgrade the pump, play it safe, it takes a little over $100 and 30 min's to install.
Old Mar 18, 2009 | 10:52 AM
tnt1106's Avatar
call me if you want as i am currently on e85, but as above really you need pump + injectors to have any real power benifit from e85.
5k6
E85 / Ethanol
Dec 20, 2016 05:13 PM
Womb Raider
Nov 4, 2016 07:05 AM
BriK
E85 / Ethanol
29
Jun 12, 2013 09:16 AM
EVOL2003
Jul 25, 2010 03:04 PM
bluemonster2
24
Dec 21, 2009 02:30 PM
