e-85 EGT's
Old Mar 26, 2009 | 07:02 PM
KenMasters's Avatar
e-85 EGT's
Would someone who runs ethanol please post egt's, I'd like to compare notes. Cheers!!!
Old Mar 26, 2009 | 07:56 PM
Evo H8's Avatar
Also curious.... subscribed.
Old Mar 26, 2009 | 09:57 PM
Jim in Tucson's Avatar
I'm very curious as well.
In my never ending search of E85 results. I have seen some info on other forums of 100-200 degrees lower EGTs. There was no actual before and after logs however. So hard to say what else had changed: was the gas tune rich and the E85 tune lean, was the timing aggressive on one but timid on the other, what part does boost play, etc?
Id like to see back to back data, before and after an E85 tune, 11:1 AFR on gas and 12:1 AFR on E85 - I'd call that equivalent, with max timing on both, and at the same boost level. That would seem like a fair comparison of EGTs to me.
I would expect the EGTs on E85 to be 150 degrees less, perhaps even more if the gas was 91 octane.
What does anyone else think?
Old Mar 26, 2009 | 11:04 PM
GST Motorsports's Avatar
12:1 is conservative on E85?
Old Mar 26, 2009 | 11:36 PM
I changed the wording...thanks.
Old Mar 27, 2009 | 11:32 AM
KenMasters's Avatar
Bump! Anyone? Bump!
Old Mar 27, 2009 | 02:51 PM
awdboosted's Avatar
Not to dump on your post. But EGT are not a good way to tune. use a Wideband. Plus EGT are going to be much cooler then pump gas..
Old Mar 28, 2009 | 07:27 AM
KenMasters's Avatar
I wouldn't tune by EGT's so don't assume anything. I am tuned with a wideband o2 and a dyno, by a professional. I would simply like to know if my EGT's are reading right.
w.o.t. 1300*F
idle 850*F
Defi D-Gauge EGT
efaustin
Oct 7, 2015 06:30 PM
EvoDan2004
May 2, 2010 12:46 PM
scout35316
11
Mar 12, 2010 02:05 AM
superlemonevo
10
Jan 20, 2010 08:42 AM
unknown2
May 9, 2005 03:18 AM
