switch
Old Mar 30, 2009 | 08:26 PM
03evo8kevin's Avatar
switch
is there any switch u can wire up to the stock ecu to switch maps cause i wanna get tuned for e85 after getting everything i need but not to many places have e85 so i wanted to be able to switch back to a 93 or 91 map when there is no e85 is this possible?
Old Mar 30, 2009 | 08:44 PM
GST Motorsports's Avatar
On 03-04 evos you can do it with the factory intercooler switch using the Tephra ECU ROM mod.
Old Mar 31, 2009 | 04:12 AM
what is that and hot a source or url where i can get it, how about a how-to?
Old Mar 31, 2009 | 10:33 AM
skiracer's Avatar
Check out the first post of this thread, paying particular attention to item #2
https://www.evolutionm.net/forums/al...ints-tips.html
Old Apr 1, 2009 | 06:21 PM
thats good info but dont tell me how to wire the switch up and where u get the ecu rom or hot to do tune the ecu to work like that
Old Apr 1, 2009 | 08:38 PM
Jim in Tucson's Avatar
Its all there...here is the specific link you need to the harness.
Here are the ROMs.
To keep tuning simple...tune your AFR to 12:1 (on a gasoline wideband) and use
MRFred's timing map . Can't get any easier than that.
I presume you have ECUFlash and EVOScan. And you will need larger injectors and a Walbro FP.
weeeeeeeeee
Jun 27, 2016 04:01 PM
criptballer
Jan 1, 2013 06:23 AM
Yiyo
Aug 8, 2012 04:29 AM
abazaba410
13
Apr 16, 2010 12:29 AM
Jim in Tucson
Aug 2, 2008 08:05 PM
