E85 and Emissions
Old Apr 1, 2009 | 01:38 PM
sdfontanini's Avatar
E85 and Emissions
Have to get my emissions tested on Friday. Need some input.
Car's currently running e85 with 880cc injectors. Going to put my cat back on, but was wondering if I'd pass without retuning my Evo.
My buddy has a specific map just for emissions that leans the car out quite a bit, but I don't want to drive the 30 minutes each way with that tune cause I'm afraid of it hurting my engine. My tuner is 30 miles from the emission station so what do you guys suggest ?
Thanks in advance.
Old Apr 1, 2009 | 01:43 PM
Creamo3's Avatar
Thanks in advance.
Do they perform a sniffer test or just pull the code history from the OBDII port? Also, not sure what sort of map your buddy is going to put on your car but it might not make any difference if your car is not going into open loop fueling.
Old Apr 1, 2009 | 01:44 PM
Yes I'm sure they do the sniffer test.
Old Apr 1, 2009 | 01:52 PM
Anyone?
tuned to e85 planning on putting on my cat and want to know if I'll pass emissions.
Car's still got the stock 8 turbo but does have 880cc injectors with a walbro 255
Thanks
Old Apr 1, 2009 | 02:10 PM
chaotichoax's Avatar
I really don't see why you wouldn't pass with the stock cat...as far as safety...just don't boost a lot and if you want to be extra careful turn your boost down
Old Apr 1, 2009 | 02:17 PM
EvolNinja's Avatar
Why don't you get the rom from your tuner, get yourself the software to flash your ecu and the tactrix cable and do it yourself so you don't have to worry about driving 30 miles on a different tune??
Old Apr 1, 2009 | 02:25 PM
Gusl's Avatar
Man, just dont go into boost. Drive slow & take your time.
You should not have any issues.
Move to Miami, no emission testing here
Yeah I have to get the test done on Friday, gonna see if my tuner will let me borrow his computer for the morning. Probably the best bet.
Old Apr 1, 2009 | 09:07 PM
Jim in Tucson's Avatar
You don't need a special "lean" flash to pass emissions, IMHO. If you are well tuned you will be fine. I'd stop down the street and turn the boost down to the can pressure just for general purposes.
I read someplace that a car on E85 sans cat emits far less pollution than a gas engine with cat. However, I would put the cat back on just for window dressing.
Please update how your E-test turns out.
italianevo88
Apr 7, 2010 11:12 AM
sdfontanini
May 13, 2009 07:09 PM
cobra2evo
Midwest Region
Mar 28, 2007 11:58 AM
Freddursticus
Mid-Atlantic Region
12
Jun 15, 2006 04:14 AM
RichJ
Feb 1, 2004 01:35 PM
