CES eth content sensor installed, flex fuel patch coming soon
The high/low maps will be able to represent any amount of ethanol that the user desires, so what you suggested is pretty much how it will work. For instance, I'm consistently getting about 75% eth from my e85 filling station, so my high eth map will be setup for this ethanol content. Even though WA and OR gasoline filling stations now all use about 10% eth, I'll likely keep my low eth map tuned to 0% eth to allow for situations where I road trip to a state where ethanol is not required in gasoline.
I believe there was only enough memory for a second set of maps when tephra did his mod so this patch won't create new maps except for perhaps the interpolated one. Mrfred, correct me if this isn't your intention.
If you are using the toggle to switch from low to high boost, then for sure it will go away in m1 because the ethanol content signal will be fed into ADC_0F which is the same input used for toggle-switch based map switching. If enough people want low/high boost, I may be able to implement some alternative means, but that wouldn't happen until m2.
Wow man, mrfred your are geniune genius!!! Amazing stuff, as usual I cant wait to try this out
Anytime your in the Philly area hit me up, they'll be a few beers in it for sure!!!
