E-85 a/f
Old Sep 14, 2009 | 06:06 PM
  #61
Jeovannie's Avatar
^+1 on that
Old Sep 23, 2009 | 12:13 AM
  #62
4drboost's Avatar
Originally Posted by crewdawg130
can we get back to the E85/AFR topic?
We can start a EGT thread if you guys want?
Yes please let us get back to the OP.
Old Sep 23, 2009 | 06:37 AM
  #63
97TSiAWD's Avatar
I'm not sure there is much more to cover on this topic. There is no general consensus as far as a "perfect" A/F ratio since some have seen power gains going leaner than 12.0 while others have not. Going leaner will certainly leave less room for error, especially as the ethanol content changes during the cooler months.
As always, each car and setup will have different results, and each driver/tuner will have different needs (i.e. all out power, safe tune, etc.) I've found it best to just try it on my car and monitor the results.
Old Sep 23, 2009 | 07:27 AM
  #64
mrfred's Avatar
Perhaps its not quite that random. I think it depends mainly on the ethanol content of the fuel. True E85 does well at 12:1 and leaner. For Fall/Winter blends, as ethanol content goes down, good power is found at AFRs richer than 12:1. Vehicle-to-vehicle variability is always there, but it should be secondary to ethanol content effects.
Old Oct 11, 2009 | 10:15 AM
  #65
awdboosted's Avatar
Just a side note. E85 runs much cooler and Evo Exhaust valve are inconel from the factory.
I agree with mrfred because its of the type of fuel you can running leaner but the benefits aren't any greater. I would also be concerned with running too rich because you can run into cylinder wash down.
Old Oct 11, 2009 | 10:41 AM
  #66
TTP Engineering's Avatar
I have a hard time believing the stock exhaust valves are inconel.
Old Oct 11, 2009 | 08:36 PM
  #67
crewdawg130's Avatar
+1....Yea not so much
I dont know but Inconel there not.
Old Oct 12, 2009 | 08:13 AM
  #68
awdboosted's Avatar
Lets put it this way. I know some who is very fast that uses stock evo exhaust valves because they are inconel. I can't say who thou.
Old Oct 12, 2009 | 08:41 AM
  #69
Um, no.
Old Nov 16, 2009 | 07:04 AM
  #70
The USAF agrees with you
SmurfZilla
Aug 16, 2015 03:50 PM
hiner005
12
Jun 28, 2014 11:32 AM
kpt6
Mar 21, 2014 05:12 PM
rcantu
Feb 21, 2014 07:43 PM
