Help
Old Aug 28, 2009 | 05:27 PM
lan_evo_mr9's Avatar
Help
If anyone could send me a link to an older version of ecuflash it would be much appreciated. Too long of a story to explain. I don't think the drivers on the new version are installing correctly on my laptop, so my openport 1.3 won't install correctly. I tried posting on ecuflash forum but haven't gotten any help yet. I have an autox tomorrow and really need to flash in a different map for it, so it is a little urgent. Any help would be appreciated. Thanks.
P.S. I can't use a version lower than 1.28 I believe.
Old Aug 28, 2009 | 05:30 PM
Justin VIII's Avatar
i have version 1.35 i have no idea if that will help you though
Old Aug 28, 2009 | 05:32 PM
That would be just fine. Please pm me a link of some sort. Thank you, thank you, thank you.
Old Aug 28, 2009 | 05:44 PM
Please send me older versions of ecuflash. Bump.
Old Aug 28, 2009 | 06:49 PM
logic's Avatar
http://www.norcalmotorsports.org/use...lash_versions/
Old Aug 28, 2009 | 07:10 PM
That absolutely worked to fix my driver issues! Thank you very much. Unfortunately, I need a version a little bit newer. I keep getting parse error messages when opening ecuflash and they won't stop until I reboot.
Old Aug 28, 2009 | 07:50 PM
The 1.39 version worked perfect, except I need the xml for my base. 20081101 is the base xml I need. Just a little more help and I'm there. Thanks guys.
Old Aug 29, 2009 | 12:21 AM
GST Motorsports's Avatar
20081101?? what is that?
Old Aug 29, 2009 | 11:46 AM
Base file xml- the newest version. That base file appeared on the 1.41 and later versions.
Old Aug 29, 2009 | 01:10 PM
oh dude sorry man, i just came on from yesterday. i see you got a fix? if not i can still send you the older version just pm your email and ill send it
Old Aug 29, 2009 | 09:09 PM
Problem resolved- got the xml needed. all good in the hood.
Falcon_2003
Jul 1, 2016 07:35 AM
EvoOtto
Oct 29, 2015 02:05 PM
TommiM
Jun 9, 2014 10:10 PM
SquattingDog
Jan 30, 2009 08:48 PM
Skim003
May 29, 2008 02:02 PM
