Just found out my e85 evo8 drive fine with 93pump gas, wow!!
recently it's cold here like 25 deg, my car have problem starting in the morning with full tank of e85. So i decided to put regular unleaded 93 pump gas in it, about 10 gal. I thought the car would drive like crap with 93oct., but it actually drive fine, and smooth. The only different i noticed is when under throttle, the wideband ratio drop to 10.0 compared with 12.0 w/ e85 and boost spool up is a little slower. 10.0 ratio means the car run a little richer i think. Hope this give every one a head up
i dont have a knock cel
And yes, we advanced the timing to like 18 degree. Well, its great to know that u can run regular pump gas (temporary) in case u ran out of e85 somewhere.
And yes, we advanced the timing to like 18 degree. Well, its great to know that u can run regular pump gas (temporary) in case u ran out of e85 somewhere.recently it's cold here like 25 deg, my car have problem starting in the morning with full tank of e85. So i decided to put regular unleaded 93 pump gas in it, about 10 gal. I thought the car would drive like crap with 93oct., but it actually drive fine, and smooth. The only different i noticed is when under throttle, the wideband ratio drop to 10.0 compared with 12.0 w/ e85 and boost spool up is a little slower. 10.0 ratio means the car run a little richer i think. Hope this give every one a head up
the other reason i fill up with regular unleaded is that the e85 pump at the gas station that i went to, take very long to fill up. Especially in the morning, i think e85 frozed up or something. Do you guys have problem with e85 very slow fill up?
You are going WOT with pump gas on a E85 map?
Vented block.
btw, proper cold starting on E85 is possible with correct tuning.
Also your fuel trims will most likely go full negative and throw a CEL.
- Bryan
Vented block.
- Bryan
I can understand filling up with 93 or 91 on an e85 map if it is literally a must and you have no other choice, but with that being said I would never go into boost. Like GST mentioned above...that is a sure-fire way to blow your engine. Why would you go full boost on an e85 map with 93 anyways? Really?
Why in the world would you drive the car in boost knowing that you put pump gas in. Sure you can get by limping around on pump gas - but you need to "limp" around and stay out of the throttle.
You should have a Tephra ROM and you can push a button and swap maps. It's too easy, get your tuner earning his money.
In summary, the heads-up is to you - not us. What you are doing is a BAD idea. Especially on a Red at 30 psi.
turbotaloon95
29
Jul 12, 2016 07:42 AM
GHEvo8
Apr 15, 2014 03:50 PM
