E95 What is the verdict.
Old Jan 29, 2010 | 02:49 PM
JohnBradley's Avatar
E98 is typically straight and they act like its not. That or it has rubbing alcohol or 87 octane but having gotten splashed in the face by it on accident I cant say I tasted any gasoline. We have found it uses more like 40% more than gas so 10% more than e85. 5% meth isnt really enough to worry about, I wouldnt think itd be needed to purge the system. Over the long run it might do something we dont want but itd take awhile.
Old Jan 29, 2010 | 02:50 PM
logic's Avatar
Originally Posted by buchnerj
The tuner is going to have a rough time with cold winter start ups, especially up in Illinois, as E-98 is pretty detonation resistant. 108-115 RON. Either way, you definitely have some competent tuners up in that region and I am sure someone can help you out.
A small suggestion here: a fuel heater can work wonders for higher ethanol percentages. Think a battery blanket (those from Canada or the northern states will know what I'm talking about), but for your fuel filter or rail, and you have the right idea.
Delphi did some interesting work in this area; they have a paper discussing heated injectors for cold starts on Ethanol, using Brazil (mecca for high ethanol content) as a test case. Pretty neat stuff. (See also, if you have an IEEE membership, this paper discussing hydrogen-enrichment of ethanol for improved low-temperature operation; note the summary, which points out that pure ethanol cannot generate a potent enough vapor/air mixture below 11C to ignite.)
Tuning only goes so far; at a certain point, the laws of physics kick in, and you have to start accommodating with warmer plugs, raising the fuel and/or combustion chamber temperature, etc.
Old Jan 29, 2010 | 10:23 PM
Wickedwhite8's Avatar
This has been some good input. Thanks guys.
Old Jan 29, 2010 | 11:43 PM
tedd69's Avatar
Sorry for my noobness. Do you need any modifications to run ethanol on an stock evo or regular car? Does Ethanol fuels give you more hp?
Old Jan 30, 2010 | 08:53 AM
buchnerj's Avatar
Do some searching my friend.
https://www.evolutionm.net/forums/al...ints-tips.html
https://www.evolutionm.net/forums/al...vs-93-oct.html
https://www.evolutionm.net/forums/al...85-vs-c16.html
Almost all of the Alternative fuel section is dedicated to E-85, its uses and characteristics.
Old Jan 31, 2010 | 02:25 PM
tedd69's Avatar
thanks for the links.
Old Jan 31, 2010 | 10:24 PM
crispeed's Avatar
Originally Posted by Silk
Or mix it with VP Q16 or Import like some of the shops that run "E85" in there race cars
E85 does not mix with leaded fuel.
Would love to know some of those shops that run E85 belended with the above fuels.
Originally Posted by Wickedwhite8
I dont trust the inconsistent mixes at gas stations.
Buying E95-98 can be just as inconsistent as at gas stations. You got to always check content if it's such a big concern to you.
Old Feb 1, 2010 | 01:57 PM
^ Really. I didn't know that. Thanks
Old Feb 1, 2010 | 02:24 PM
Gordian79's Avatar
I got a quote from them $220 to ship $150 barrell yikes.I get my E98 shipped from MN.My plan is to drain tank day before track.Fill it up with E98 drive to track.Take two extra jugs of fuel and drive home.total 120 mile round trip i should be able to make it with the roughly 30 gallons ill have with me.
razorlab
E85 / Ethanol
115
Sep 14, 2019 12:28 PM
EvoMike
Midwest Region
Aug 13, 2014 08:28 PM
Evo5madness
Jul 11, 2014 01:55 PM
aronjaskim
10
Apr 13, 2011 06:10 PM
BCOZEVO
12
Oct 19, 2009 09:02 PM
