I just picked up my first 15 gallons of E85 - a few questions.
Old Apr 30, 2010 | 02:27 PM
TheBoz's Avatar
I am running 1350cc injectors and -6an line from my bosch 044 pump to the rail.
Why kind of power will those injectors support along with that pump.
The next one is, I will be using my Cali pump gas map as my starting point, do most people just at 20% fuel to the map can try to fire the car?
I am also switching to hotter plugs and a smaller gap and everything else that is recommended in the Generic Info about E85. I am hoping to run 30psi on a 37r and about ~600awhp.
Old May 1, 2010 | 01:21 PM
Jim in Tucson's Avatar
Sounds like a plan.
I would suggest more like 25-30% additional fuel over pump gas. Or, use your suggested 20% number and simply turn your boost down as low as you can and work your way up to 30psi tuning as you go.
Old May 2, 2010 | 10:10 AM
TheBoz's Avatar
So yesterday I get a wild hair up my *** to try out some E85. I have been thinking about doing for about 6 months now. I finally got tired of spending 15 bucks a gallon on Q16. So I finally go the galant to about 700whp on Q16 @ 35psi. I had some fun with the car and drove it around killed some cars on the freeway, and thne drained the last 2 gallons of Q16 out of my car.
I simply put in 5 gallons of e85, went to my fuel map and added 30% across the board. The car fired right up, I still need to do a little bit of work on the idle but so far it idels pretty well.
So on to the tuning. I dial in the 0psi part of my map and get the AFR's inline. After that we switch to 10psi, which is as low as my wastegate will go. I dail the AFR's in on that. Then we start cranking up the boost. We get to 19psi, and without making any timing changes from my Q16 map the car is making 492/359 on VDR Dynojet Avg.
The knock on the car is really good, the car has yet to pull anytiming. I do still need to add some more timing. I think that I can get almost 400ft of torque at 20psi. I just need to get a little more agressive with the timing. The car pulls awesome at 19psi, and I am at 65% duty cycle on my 1350cc injectors.
So I will richen up the AFR's currently about 12.5 I am going to get into the 12.2 area and add a ton of timing to this car.
If anyone is interested in my maps they are here:
http://forum.aempower.com/forum/inde...c,26131.0.html
Womb Raider
Nov 4, 2016 07:05 AM
Jonno99
Oct 19, 2015 01:06 PM
mx5tc
E85 / Ethanol
May 9, 2009 12:39 PM
boostincincy
E85 / Ethanol
30
Mar 8, 2009 12:10 PM
