can sitting e85 cause for an AFR change?
Old Jul 3, 2010 | 04:52 PM
norcalSRTrida's Avatar
So my car's been sitting for about 2 months now while i tried to sort out some boost controller issues, and just havent had time to actually spend on it while i was consumed w/ some summer courses trying to wrap my degree up.
i took my car out the other night on low boost to check everything over, and the AFR's were about a full point too lean...around 13.0-13.2, while the AFR's were usually ~12.0-12.2..
can e85 that's been sitting in a gas tank for 2months be the cause for the sudden lean AFR's?
the car is filled basically to the top, so i got a full tank of gas to burn off before i can go refill and see if there's any changes, but i thought id ask in the meantime.
Old Jul 4, 2010 | 08:14 PM
Jim in Tucson's Avatar
Not likely due to the E85 sitting. I'd guess the difference is simply due to weather differences - particularly temp and baro.
Read this thread:
https://www.evolutionm.net/forums/al...notes-afr.html
Old Jul 7, 2010 | 08:44 AM
mrfred's Avatar
Ethanol is hygroscopic (likes water), so if left in open air, it will absorb moisture from air. As long you didn't leave the gas cap off, that wouldn't be an issue. Suspect its what Jim said.
Femi
AEM EMS
23
Apr 5, 2016 11:38 AM
asu11
E85 / Ethanol
44
Jul 17, 2015 01:31 AM
iTune
E85 / Ethanol
58
Nov 16, 2013 05:58 AM
CDrinkH2O
Sep 7, 2013 05:51 PM
goofygrin
86
Aug 6, 2013 08:09 AM
