Miss when not on WOT
Old Jul 20, 2010 | 01:38 AM
poyz's Avatar
Hi all
Hoping you guys can help me. I'm getting what feels like a miss when going through the gears on light / moderate throttle (basically when not on WOT) when coming into boost.
I've done several logs and I think I've found the culprit, timing is dropping to -4 then climbing to +22 then it continues it's normal path. (Sorry I can't log boost, but the car is running 24-25psi on E85)
The problem doesn't exist on WOT. I've attached a screenshot and a copy of the log.
My timing map doesn't reflect what I'm logging and lean spool is disabled.
Thanks.
Old Jul 26, 2010 | 01:55 PM
THUB's Avatar
This could be your crank sensor going. One of buschur's personal cars had a similar problem and ended up blowing the crap out of the head gasket/ head. I don't know how to go about testing for this but it sounds similar.
Old Jul 26, 2010 | 11:37 PM
poyz's Avatar
Thanks for the reply.
In the mean while, I've checked my plugs and re-gapped them to back 0.024 inches (0.6mm) ... they were about about 0.028 inches (0.7mm), I think Mitsubishi must have re-gapped them when I get it serviced, because they were definately 0.024 inches when I had it tuned. I'll report the results back here after I've driven it a little more.
Also, to test the crank sensor I'll see if I can borrow a good known working one off a friend with an Evo IX and report back here. But I'll see how I go with the plugs first.
Edit: Just realised you meant Crank Angle Sensor, not Camshaft Position Sensor (changing the the CAS isn't as straight forward as the CPS)
butte
Nov 12, 2015 04:23 PM
ehall20
Apr 5, 2014 05:26 PM
EvoIXPilot
Feb 11, 2013 07:20 AM
NOMIEZVR4
17
Feb 3, 2012 08:34 AM
xtremeIX
Feb 11, 2008 09:56 AM
