Best MBC for stock turbo
What would be the best mbc for 30+ psi using these stock turbo wastegate actuater my current mbc really old is having trouble getting past 29psi and flutters while tapering down.no ebc or 3 port talk thanks
Hallman or Dejon. Whatever you can get first. Had both controller and they both work amazing.
And for 30psi on stock turbo.....do NOT go 30 psi, that is ridiculous. Stay anything below 25 or 26max!
Only way you'll hit 29-30 is if you're tuned on e-85/race gas. Even if that, you better have some good injectors.
Hallman boost controller is definitely the best of the best for MBC's.
However, I will be switching to the Grimmspeed 3-Port for better boost control. 27 PSI of boost in first gear holding past red line? Sign me up
-Bink
-Bink
-Bink
im sure it can handle 30lbs
