setting up Zeo ECA and FF sensor
Old Aug 11, 2010 | 05:27 PM
str8dum1's Avatar
Shouldnt a 40% alcohol by volume (like the gin I used to test the sensor) register as E40?
Old Aug 11, 2010 | 06:54 PM
l2r99gst's Avatar
I'm pretty sure the sensor is measuring the dielectric properties of the gas/ethanol mixture to find the percentage of ethanol (ethanol is more conductive than gasolione). Since your have no gasoline in your drink there, I don't think it will work how you are thinking.
Just looked up some values for dielectric constant at 25C
Ethanol - 24
Gasoline -2
Water - 80
So, that shows why your results aren't what you expect. Your sensor isn't an alcohol sensor...it's a calibrated sensor to determine the ratio of alcohol to gasoline.
Old Aug 11, 2010 | 07:19 PM
1outlaw's Avatar
The problem is exactly as stated by 12r99qst-- This is the very same issue that a Kent Moore test kit in a GM shop will do if they leave the sample on the tester too long. The moisture acquired from air in such a tiny sample happens quickly and will render the results useless.
Old Aug 11, 2010 | 08:16 PM
str8dum1's Avatar
ahh so its really not an ethanol content gauge, more an ethanol ratio gauge.....
Thanks!
Old Aug 12, 2010 | 09:30 AM
Zeitronix's Avatar
GM flex fuel sensor was designed to detect ethanol content in petrol not to be your cocktail mix helper.
Old Aug 12, 2010 | 02:12 PM
Garth's Avatar
but...but...it seems like... some of these bars around here really water down the booze.
Could it be re-calibrated???
Old Aug 12, 2010 | 02:25 PM
1outlaw's Avatar
Heck- the bars will likely buy one to try to tell us they are serving everclear.
Old Aug 12, 2010 | 03:00 PM
skiracer's Avatar
BTW, what car is this installed in ? The rear view mirror and sunglass holder don't look like an Evo.
Old Aug 13, 2010 | 05:01 AM
str8dum1's Avatar
A twin 6262 g35, but there's not much E85 goin on in the VQ forums.
Old Aug 13, 2010 | 08:07 AM
skiracer's Avatar
Sweet, post some pics/stats on the car
Old Aug 13, 2010 | 11:15 AM
str8dum1's Avatar
Pretty standard build with dual intank walbros, PTE1200cc, Haltech, JWT cams but super laggy with the 3.5l.
Rebuilding right now with a 3.8L BC stroker, carrillo rods to push the power to the left some.
Getting parts together for the E85 swap when I get the motor back.
Attached Thumbnails setting up Zeo ECA and FF sensor-engine-swap-265-800.jpg   setting up Zeo ECA and FF sensor-engine-swap-391-800.jpg   setting up Zeo ECA and FF sensor-engine-swap-338-800.jpg
Old Aug 13, 2010 | 11:18 AM
l2r99gst's Avatar
Very nice! Are there any single turbo kits for your car? You could spool a huge turbo pretty fast with all 6 cylinders and move the curve well to the left.
Old Aug 13, 2010 | 11:33 AM
andrewzaragoza's Avatar
or do twin turbos but use a smaller snail.
Old Aug 13, 2010 | 12:12 PM
Jim in Tucson's Avatar
Wow! Peak torque at 7,000 rpm. That G35 must spin the tires at the END of a 0-60 sprint!
Old Aug 13, 2010 | 06:14 PM
Zeitronix's Avatar
When we test ECAs we have a small sample of E-85 exposed to the air. E85 is so hydroscopic it dehumifies the room After a while it reads E86, then E87 and so on. I tested some ECAs today fresh of assembly line and I got E94. Had to dispose the sample and get fresh E-85.
